Author Topic: Lakemaster Plus Icons  (Read 11284 times)
Offline RonnieB
  • RonnieB
  • Software: 2.0
« on: April 27, 2016, 04:43:29 PM »
Is there a way to turn off some or all of the icons on Lakemaster Plus? When I am trying to see a full view of lake the icons cover everything up. Not too much of a problem when I zoom real close.
Also, what are the icons? I thought I read where you could cursor over icon, click and get info as Navionics does it.
Re: Lakemaster Plus Icons
« Reply #1 on: April 28, 2016, 01:39:40 AM »
You should be able to cursor to the icon and then press the checkmark button for info ...
You may be able to turn some of that off under the Chart tab and down to "Chart Detail" = set to "Custom" ...which will add another "Menu" selection directly under the "Chart Detail" "Menu" ...
Then enter the Custom Detail "Menu" for selections to turn off ...
Offline RonnieB
  • RonnieB
  • Software: 2.0
« Reply #2 on: April 28, 2016, 07:57:06 AM »
On my Onix, and LM+ SE States I do not have Chart Detail and icons do not open up when clicked on. May just be MS lakes?
« Reply #3 on: April 30, 2016, 10:12:11 AM »
My mistake Ronnie ... My info of the Chart Detail "Menu" was for core units ...
I see now in your sig you have ONIX ...
I will have to experiment on my ONIX and see if I can find some options for turning anything off on the map card ...
Offline RonnieB
  • RonnieB
  • Software: 2.0
« Reply #4 on: May 01, 2016, 05:35:20 PM »
Thanks Rickie, I sent HB CS an email asking them also. Some Lakes there are not many Icons to worry about.
This may just be wishful thinking, but is there a way change at what zoom level the the depth numbers appear? Sometimes I like zooming out and looking at a larger map area.  I hate to have to cursor over an area and zoom in to see depth numbers, then zoom out find another area then zoom in again to see depth. For a remedy, I fine tune color/depth/range to what I am looking for. (actually pretty neat).
« Reply #5 on: May 02, 2016, 01:36:37 PM »
I'm not sure Ronnie ... I'll have to do some experimenting on my ONIX to see if I can find something for you ...
Offline RonnieB
  • RonnieB
  • Software: 2.0
« Reply #6 on: May 04, 2016, 08:13:01 PM »
Humminbird reply:
"Thank you for contacting Humminbird. We appreciate your interest in our products. The feature turning icons on/off can be done with the Navionics card not Lake Master unless you are zoomed in close. In the Onix unit under your favorites you can click on the icon."
Yes or No???  I knew that on Nav & LM you have to zoom into see some of the Icons. But I do not know about the favorites???  I won't be able to look at my Onix for 2 wks.
Last post October 26, 2009, 07:11:27 PM
Last post May 30, 2012, 11:56:14 AM
by sharky12
Last post November 10, 2010, 06:56:51 PM
Last post June 08, 2011, 10:36:10 AM
Last post January 08, 2012, 12:21:03 PM
Last post March 17, 2012, 05:46:50 PM
by bass1958
Last post April 08, 2016, 10:54:08 AM
by RonnieB
Last post July 06, 2019, 10:13:00 PM
by knorstu
