Author Topic: 797 and the jrc ff  (Read 9429 times)
Offline sharker807
  • Unit(s): 797C2I
797 and the jrc ff
« on: March 21, 2010, 06:32:58 AM »
will having the 797 and my jrc fishfinder iterfear with each other, i would like to run them at the same time, is this possable
Re: 797 and the jrc ff
« Reply #1 on: March 21, 2010, 12:19:23 PM »
You cannot run the same frequencies at the same time or you will get interference.  If you can turn the 200kHz off on the JRC you may be OK.  I think they use 50/75/200 and the HB uses 83/200kHz.  As for the SI, it should not affect it.
Good Luck,
« Last Edit: March 21, 2010, 03:53:14 PM by RGecy »
