Author Topic: New version is causing problems  (Read 12436 times)
Offline mwniema
  • Unit(s): 858c
  • Software: 7.66
« on: April 17, 2016, 01:06:17 PM »
Just installed version 7.66 on my 858c DI, now I am experiencing the following problems.
-unit turns off sometimes for no reason
-Cannot turn On unless I disconnect from Battery
-Sometimes screen freezes during startup on Loading.... screen.
Is it possible to go back to my previous version? Or will this screw things up more?
Are there previous versions available? Found one version on this site but no details about it.
Re: New version is causing problems
« Reply #1 on: April 17, 2016, 09:54:18 PM »
I haven't seen any problems like that cause by a software update .... Are you sure you haven't developed a power problem?
Offline mwniema
  • Unit(s): 858c
  • Software: 7.66
« Reply #2 on: April 17, 2016, 11:13:44 PM »
i guess it possibly could be related to  power problem. I was out today for a test run and it worked great for a half hour then just shut off for no reason and would not turn back on right away. It did eventually turn back on after about 10 minutes. Same thing happen again after about 20 minutes, wait about 10 and it will come back on after hitting the power button.  I cannot figure out what is going on.
« Reply #3 on: April 17, 2016, 11:38:19 PM »
Do you know what the voltage on the unit displayed while it was working?
Offline mwniema
  • Unit(s): 858c
  • Software: 7.66
« Reply #4 on: April 18, 2016, 10:51:34 AM »
Yes, it was running 13 - 14 volts. Was trolling with big motor.
« Reply #5 on: April 18, 2016, 03:25:16 PM »
If you reset defaults after the update and the voltage is good ..... better give Humminbird a call.
Offline mwniema
  • Unit(s): 858c
  • Software: 7.66
« Reply #6 on: April 18, 2016, 03:51:28 PM »
Ok, thanks for your input.
Offline mwniema
  • Unit(s): 858c
  • Software: 7.66
« Reply #7 on: April 30, 2016, 12:07:01 PM »
I changed the wire connections to a different area on the fuse panel.  Last time out everything worked great! Hopefully it was just a bad connection.
« Reply #8 on: April 30, 2016, 01:35:16 PM »
You have discovered the reason it is recommended to run a power wire direct to the battery with an inline space type fuse at the battery..... Using the boat fuse panel often causes problems with the electronics.
It is still a good idea to run a wire direct to the battery.  I personally would use 12 gauge twisted pair wire.
Last post February 10, 2011, 05:37:41 PM
by IRC Kevin
Last post March 14, 2011, 07:19:11 PM
Last post March 16, 2011, 09:41:22 PM
by Sigler
Last post July 02, 2011, 05:10:34 PM
Last post September 19, 2011, 02:42:43 PM
by stillbear
Last post August 02, 2013, 11:16:29 AM
by tanman
Last post June 04, 2014, 04:19:21 PM
by steelebob
Last post August 10, 2015, 07:53:26 PM
by gt
