Author Topic: Helix 10 si NMEA connection  (Read 7920 times)
Offline Pck
  • Unit(s): 788ci
« on: March 15, 2016, 11:43:37 PM »
Humminbird Greg....... I have a new helix 10si and want to send gps info to my Standard Horizon GX1600 VHF. I see you have a document titled "Connecting the NMEA Output from a 700 series unit to another NMEA device"......Would that same connection apply to the helix 10??? I have the AS HHGPS cable. Thx
Re: Helix 10 si NMEA connection
« Reply #1 on: March 15, 2016, 11:52:36 PM »
Greg hasn't been able to check in due to increased training duties at HB ...
And I know nothing about NMEA ...
If no one addresses your question ...you can call HB for support ...
1-800-633-1468
Offline Pck
  • Unit(s): 788ci
« Reply #2 on: March 16, 2016, 12:01:40 AM »
Thx rickie, I'll give it a couple a days.......
« Reply #3 on: March 16, 2016, 12:04:11 AM »
Pck ... Can you link me to that document ... ??
It wouldn't hurt for me to read it (even if I may not understand it) ...
Offline Pck
  • Unit(s): 788ci
« Reply #4 on: March 16, 2016, 12:17:00 AM »
If you google "Connecting the NMEA Output from a 700 series unit to another NMEA device" it will come up. Looks like the doc came from HB Support, FAQ
Offline Pck
  • Unit(s): 788ci
« Reply #5 on: March 16, 2016, 05:44:24 PM »
Rickie..... Just talked to HB support, the only cable they have to support NMEA GPS output from a helix 10 (or any other HB GPS/combo unit) is the AS HHGPS cable and the document I mentioned is good for the wiring info. Basically, it's pretty simple - from the AS HHGPS cable, the black wire (-) connects to whatever color the NMEA ground (-) wire is on the unit you are sending GPS info too (in my case, a GX1600 VHF, green wire), and the AS HHGPS white wire (+) to the NMEA GPS input (+, blue wire on the 1600). When I receive my 10si and wire it up, I'll let u know......
« Reply #6 on: March 16, 2016, 11:19:12 PM »
Is this info from HB going to answer your question then ??
Offline Pck
  • Unit(s): 788ci
« Reply #7 on: March 17, 2016, 04:45:17 PM »
Should... We'll see when I get it wired
Last post March 02, 2012, 02:55:29 PM
Last post April 16, 2014, 01:00:44 PM
Last post May 12, 2017, 05:13:43 PM
by sylvan
Last post June 14, 2017, 09:55:22 AM
by Juicegoose
Last post July 25, 2017, 08:03:59 AM
Last post February 19, 2024, 02:16:30 PM
by Togue Troller
