Author Topic: 598 ci si hd replacement parts  (Read 11569 times)
Offline jesse1378
  • Unit(s): 598ci SI HD Combo
« on: February 14, 2016, 04:54:44 PM »
ok, got a 598 for my birthday, thanks son. thing is I have two boats.  I've located some places to get different parts, mounting brackets, power wires. The transducers have me confused. I have seen several different ones for sale, it looks like the xnt 9 si 18t is the one I need, but there is another one listed on amazon that says it will work with the 598, and it's $100 cheaper? this will be a trolling motor mounted transducer. I want to share the unit between the two boats but I want the same setup on both. Any suggestions for part purchasing?
Re: 598 ci si hd replacement parts
« Reply #1 on: February 14, 2016, 10:26:54 PM »
You have a few options for an SI xducer for your 598 in a trolling motor application ...
The stock XNT 9 SI 180 T can be used on a TM with this adapter ...
http://www.humminbird.com/Products/AD-XTM-9/
This is the replacement trolling motor puck housing in the same compact SI ...(this one has extra shielding for possible RFI) ...
http://www.humminbird.com/Products/XTM-9-SI-180-T/
The XHS 9 HDSI 180 T can also be used with your 598 ...and it will give somewhat better SI images because of the longer SI piezoes ...
http://www.humminbird.com/Products/XTM-9-HDSI-180-T/
« Last Edit: February 14, 2016, 10:29:13 PM by rnvinc »
Last post March 04, 2011, 04:09:27 PM
Last post July 31, 2013, 08:51:44 AM
by dirrick siler
Last post February 18, 2012, 07:51:33 AM
by reddog
Last post June 20, 2012, 03:39:21 AM
by Daniel944
Last post August 28, 2012, 08:37:51 PM
by LocDown
Last post July 09, 2015, 11:24:06 AM
by Carver
Last post October 20, 2015, 08:21:38 AM
by tstorm87
Last post May 22, 2017, 04:44:50 PM
by Tamlin
