Author Topic: Waypoint sharing 998 to 798  (Read 8635 times)
Offline starkyb
  • Unit(s): 798 998
« on: February 13, 2016, 05:51:08 PM »
If I connect my units with an Ethernet cable do I have to have a mapping chip in both units.  I currently am using a Navionics gold chip in the 998 and nothing in the 798 except for the contour xd map built in to the unit.
Re: Waypoint sharing 998 to 798
« Reply #1 on: February 13, 2016, 08:41:19 PM »
You WiLL be able to share waypoints between units if you connect them via Ethernet.....but you won't be able to share mapping.
You will have to have a map chip for each unit or move one between them if you need mapping on both.
The waypoint is just an overlay on the mapping, not part of the mapping.
« Reply #2 on: February 13, 2016, 11:27:46 PM »
Only the 798 HD is Ethernet compatible ...
The 798 is not ...
Offline starkyb
  • Unit(s): 798 998
« Reply #3 on: February 14, 2016, 07:58:42 AM »
Thanks for the reply.  The lake I will be fishing is part of the the maps built in to the unit and it is the 798ci hd version.
Last post March 18, 2011, 04:57:12 AM
by stillbear
Last post July 29, 2013, 01:48:50 PM
Last post October 23, 2013, 08:29:29 AM
Last post March 02, 2014, 11:54:13 PM
by Rotus623
Last post April 17, 2014, 11:58:15 AM
Last post April 29, 2017, 11:00:35 PM
by Conrad_Turbo
Last post September 07, 2017, 10:11:11 PM
Last post June 05, 2018, 09:44:29 PM
