Author Topic: 899 si and 360  (Read 3640 times)
Offline bgump24
  • Unit(s): 899 SI
899 si and 360
« on: January 13, 2016, 06:25:37 AM »
Is it possible to connect a 360 transducer to a 899 and still have your si transducer as well i know you wouldnt really need both but i would like to keep both if possible
Re: 899 si and 360
« Reply #1 on: January 13, 2016, 11:46:45 AM »
It is possible to have both connected to the unit because the 360 is an Ethernet accessory and plugs into a different port on the back of the unit ...
When the 360 is activated - the unit shuts off the transmitters for the SI in the connected SI xducer ...
The 360 can also be used as the SI in the advanced network source tab ...when choosing the 360 as the source for SI ... The spinning piezoes in the 360 "park at home" and are used as regular SI piezoes ...
When the SI source is set to the SI xducer = the 360 is deactivated ...
« Last Edit: January 13, 2016, 11:48:29 AM by rnvinc »
Offline bgump24
  • Unit(s): 899 SI
Re: 899 si and 360
« Reply #2 on: January 13, 2016, 01:46:56 PM »
thanks what all besides the 360 unit would i need to connect it i only have a si ducer connected now nothing else no network or nothing
Re: 899 si and 360
« Reply #3 on: January 13, 2016, 06:26:50 PM »
The 360 comes with an Ethernet cable ...
If there are no other devices besides the 360 and the 899 ...you will only additionally need the AS EC QDE adapter cable for the 899 ...
http://www.humminbird.com/Products/AS-EC-QDE/
