Author Topic: Humminbird TS3 transducer switch installation  (Read 10704 times)
Offline RBrad
  • Unit(s): 585, 898c si
  • Accessories: Transducer Shield & Save, TM-HDsi
« on: January 08, 2016, 06:52:42 PM »
This switch has the red power and black negative wires, wrapped in foil.  It also has a "naked strand" wire between the foil and exterior wire plastic/rubber coating.
I assume the foil is to help with interference.  And installation shows normal red/black. Nothing on the "naked strand" wire.
Is the "naked strand" wire supposed to be hooked to ground or just left alone?  Or what purpose does it serve?
Re: Humminbird TS3 transducer switch installation
« Reply #1 on: January 09, 2016, 11:29:16 PM »
I think the foil, the bare wire, and the black wire are conductive together to dump interference to the negative post of the battery ...
I think I nipped my bare wire off at the point where I trimmed the outer casing ...
« Last Edit: January 09, 2016, 11:30:52 PM by rnvinc »
Last post May 20, 2010, 06:05:40 AM
by bearpeter1
Last post June 17, 2010, 05:37:13 PM
by keizerh
Last post October 21, 2011, 04:42:42 PM
by bobxxx
Last post February 05, 2013, 11:50:34 AM
by didier74
Last post March 26, 2013, 06:31:58 PM
Last post June 03, 2013, 10:33:10 PM
by jaconnett
Last post February 25, 2014, 11:03:57 AM
Last post March 15, 2015, 06:14:27 PM
by Spd 135
