Author Topic: Ethernet cable to extend 360  (Read 10592 times)
Offline Spd 135
  • Unit(s): 898c si 997c SI Helix 12
  • Software: All Current
  • Accessories: 360
« on: December 07, 2015, 10:09:41 AM »
I need to extend my cable and am looking for a source to get "cat5e patch cable etl verified tia/eia-568-B.2". This is printed on the 360 cable. I have extended it before by purchasing 30' extensions but I want to make a solid cable to the length I need. Thanks Mark
Offline Spd 135
  • Accessories: 360
Re: Ethernet cable to extend 360
« Reply #1 on: December 14, 2015, 06:37:24 PM »
Got it done. 140' of cable.  Runs like it should.
« Reply #2 on: December 15, 2015, 08:58:34 AM »
Well now that's interesting ...
Offline Spd 135
  • Accessories: 360
« Reply #3 on: December 16, 2015, 12:40:48 PM »
Side-scan and Scanning images from yesterday on the East Pearl River
Offline Rickard
« Reply #4 on: December 18, 2015, 05:29:14 PM »
Mark,
Have you tested the 360 as deep as 140'?
Rickard
Offline Spd 135
  • Accessories: 360
« Reply #5 on: December 18, 2015, 06:10:17 PM »
I have not.  I have had it to 85'.  But......It will hold up just fine.  I periodically check the screws to make sure they are snug.  My gopro underwater camera housing is a simple oring and it is good to 200' or more.  The 360 is much more robust.  The 360 was developed for fishing.  It was not tested (nor likely thought of for other uses) so there is no data from Humminbird.  It looks to be the first model Koensberg Mesotech scanning sonar without the bells and whistles.  In a month, or 2, I will be able to verify this but it is mechanical and built solid.  It is probably fine to a few hundred feet.  I do know that the extra cable did not affect the signal at all.
http://oceanvision.com.sg/product/kongsberg-mesotech-1071-digital-imaging-sonar-head/ (6000 meters depth rated)
« Last Edit: December 18, 2015, 06:20:38 PM by Spd 135 »
« Reply #6 on: December 19, 2015, 08:00:58 AM »
Did this Koensbery Mesotech not have patents ...??
Offline Spd 135
  • Accessories: 360
« Reply #7 on: December 19, 2015, 10:20:49 AM »
Good question.  Maybe what I was saying is this is "pretty much" the same thing.  It has an encapsulated transducer, it's oil filled and it uses a servo motor.  Or maybe the patent ran out, or permission was obtained to use with limited software.  In otherwords, only fishing software.  I don't know for sure but it seems to be the same thing and I have dropped it pretty deep and will send it to about 140' soon.
Last post March 22, 2011, 05:34:04 PM
Last post April 09, 2014, 06:30:55 AM
by bobcoy
Last post July 17, 2014, 10:41:29 AM
by ricqik
Last post March 30, 2015, 09:57:22 AM
Last post September 13, 2016, 10:26:56 PM
by bobcoy
Last post June 11, 2017, 11:52:50 PM
Last post December 06, 2018, 08:58:13 PM
by Fresnoron
Last post October 29, 2021, 08:47:11 PM
