Author Topic: xpth9 hdsi 180t  (Read 7772 times)
Offline markbigsur
  • Unit(s): 998c SI
xpth9 hdsi 180t
« on: October 25, 2015, 03:06:10 PM »
Hello all,
 I fish deep sea, mainly salmon and tuna. I have moved the transom mount transducer that came with my 998csi all over the place and have not been able to get good readings even with the regular sonar at 4-5knts.  There is so much turbulence at the transom on my 2052 trophy I/O mainly from the exhaust that  I am going to install the Thru hull xpth9 hdsi 180t transducer on the bottom of my boat.  Here is what I would like to accomplish:  1. Be able to see bait balls and and bottom on the reg. sonar while running at 20kts or so.  and 2. be able to use the side scan and DI at 2-6knts while trolling to pick up bait and fish to the sides of the boat. The water is often 2000-3000ft deep for tuna.  I set the reg sonar for just the top 300ft.  Will the SI still look to the sides even with the bottom so deep?  And will the XPTH get a good reading on reg sonar while running or will I also need a shoot thru the hull for running?
Thanks for the help,
Mark
Offline markbigsur
  • Unit(s): 998c SI
Re: xpth9 hdsi 180t
« Reply #1 on: October 25, 2015, 07:26:51 PM »
Doing some more research looks like what might work best for what I need would be an airmar  b-260.  Any thoughts on this would be appreciated.
Last post August 18, 2010, 04:08:12 PM
Last post December 31, 2012, 02:10:10 PM
by geno368
Last post March 26, 2013, 10:25:25 AM
Last post June 13, 2013, 11:05:36 AM
Last post February 25, 2014, 12:13:35 PM
by silvercloud
Last post July 09, 2015, 10:24:29 AM
by Kenneth_v
Last post March 25, 2015, 05:32:48 PM
by Bayou Basser
Last post February 01, 2016, 04:23:08 AM
by rybens
