Author Topic: US2 damage 859di  (Read 11304 times)
Offline gray6431
  • Unit(s): 1199CI 859DI
  • Software: 7.65
  • Accessories: ipilot link
US2 damage 859di
« on: October 02, 2015, 11:18:25 PM »
I was on the phone with hummingbird tech support and they told me that my built in US2 transducer could damage my 859di . Has anyone else heard this?
Offline sfw1960
  • Bringer Of The 'Bird
Re: US2 damage 859di
« Reply #1 on: October 03, 2015, 02:43:27 PM »
It uses a higher frequency than the 200/83 KHz the US/2 is designed for.
The DI uses 200/455KHz for the 2D.
Yep you can fry a DI unit on it.
Get a TM XDCR & mount it on the TM
« Reply #2 on: October 03, 2015, 10:11:41 PM »
There is a specific setup where the US2 can be connected to a 800/900/1100 series HB DI unit with the AS SIDB Y cable    ...
"Un-official" Note:  Due to warranty language HB cannot "officially" advise users of this option because the AS SIDB Y cable was not designed for the HB DI units ...the AS SIDB Y cable just happens to be wired that way ...
This only works for the 800/900/1100 series HB DI units because these specific model DI units have the "DI + 200kHz/83kHz" menu choice for the "Transducer Select" setting under the Sonar tab ...
http://bb.sideimageforums.com/viewtopic.php?t=4441
« Last Edit: October 03, 2015, 10:28:55 PM by rnvinc »
Offline sfw1960
« Reply #3 on: October 04, 2015, 09:55:10 AM »
For a guy that has a separate XDCR bow mount that looks like an angry porcupine (LOL!), why on earth would somebody split the 2D to the US/2 and STILL have to mount a DI piezo to get full functionality when a single Trolling motor mounted DI XDCR on the bottom of the motor housing can "do it all"?
I realize it's "possible" like that, just impractical.
 >:D
... ... ...  Jus' Sayin' ... ... ..
« Last Edit: October 04, 2015, 09:56:26 AM by sfw1960 »
Offline gray6431
  • Software: 7.65
« Reply #4 on: October 04, 2015, 11:25:34 PM »
it was set up that way buy the dealer my boat has an Ulterra trolling motor still trying to figure out how to wire the DI transducer
« Reply #5 on: October 04, 2015, 11:45:50 PM »
If you are wanting DI on the Ulterra... The only option is mounting a DI xducer to the Ulterra ...
And if the DI xducer has to be mounted to the Ulterra ... Why would you want to hook up the US2 ...??
Or are you wanting the DI mounted somewhere other than the Ulterra ...but still get 2d from the US2 ...??
« Last Edit: October 04, 2015, 11:50:00 PM by rnvinc »
Offline gray6431
  • Software: 7.65
« Reply #6 on: October 07, 2015, 02:16:01 AM »
I'm having a hard time figuring out how to run wire DI trans on the ulterra and let everything  work stow deploy trim and the like
« Reply #7 on: October 07, 2015, 09:19:14 PM »
There is this option ...
| General Equipment Discussion | Texas Fishing Forum
Offline gray6431
  • Software: 7.65
« Reply #8 on: October 09, 2015, 07:13:08 PM »
Ricky Thanks for the link. I'm in the middle of trying that very thing. thanks again to everyone and I'll post a pic when I get finished. Gray
Last post June 17, 2010, 05:37:13 PM
by keizerh
Last post February 07, 2012, 11:40:10 AM
Last post July 12, 2014, 03:09:28 PM
by JPWalnuthill
Last post March 19, 2015, 03:47:10 PM
Last post October 18, 2015, 09:21:29 PM
by larry crouch
