Author Topic: 999 SI  (Read 4448 times)
Offline fishbone
999 SI
« on: September 24, 2015, 12:33:37 PM »
I am considering the 999 for a bow mount.
I have a five year old console mounted 998 that is easily washed out by bright sunlight. It would not be usable in a bow application.
Are recent versions brighter and able to be used in a somewhat flat (up) display angle?
2013 Stratos 189 VLO
E-Tec 150 HO 150hp, 6" JP
80# Fortrex, 2ea 8' Power Poles
HB 998cSI @ Console, HB 999HD SI @ Bow
Re: 999 SI
« Reply #1 on: September 24, 2015, 04:33:10 PM »
The original 998 SI Combo had CCFL backlighting (which I assume yours is if your unit does not physically have "HD" in the model name and printed on the SD Card slot door) ...
The 998 HD SI Combo had LED backlighting (which was the only change made with the added "HD" designation ... It is easier for sunlight viewing)
The 999 HD SI Combo also has LED backlighting (which is easier for sunlight viewing) ...
« Last Edit: September 24, 2015, 04:37:13 PM by rnvinc »
Offline fishbone
Re: 999 SI
« Reply #2 on: September 24, 2015, 05:12:16 PM »
Thanks, Rickie
