Author Topic: unit doesn't work properly after about 95 ft  (Read 13568 times)
Offline chetmaychua
  • Unit(s): 797C2 SI Combo
  • Software: 5.450
« on: September 23, 2015, 01:47:46 AM »
Hi all,
My unit is 797C2 SI combo, firmware 5.450
I recently took the boat to the ocean. Everything worked fine until about 95FT. The unit shown depth reading at 1ft and nothing else was working properly. When I took the boat back to around 80 ft and the unit started working normal again.
Troubleshooting:
Contacted tech support while having trouble in the ocean, they walked me through all the settings and didn't resolve.
Replaced the power cable with a brand new one, bought a new battery just dedicated for the unit. Power is out of the question.
Upgraded firmware to 5.450 latest.
What else should I replace? I am thinking about buying a new transducer.
Any suggestion is appreciated.
CMC
Re: unit doesn't work properly after about 95 ft
« Reply #1 on: September 23, 2015, 09:38:40 AM »
These units are not designed for the ocean (even though they state they'll go very deep).
They are mainly used for shallow water Bass fishing.
They're have been a few complaints when trying to use Humminbird's in deep water.
If you want something proven for the ocean, maybe look at a Furuno.
The new models (Onix), may be capable of using in deep water.
Offline Landry
  • Unit(s): 899
  • Software: 2
  • Accessories: Ethernet and HDSI SI ducer
« Reply #2 on: September 23, 2015, 07:03:25 PM »
It should still read waaaaaay past 80' though. Cmon. Ther is something wrong. Return it.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #3 on: September 23, 2015, 07:14:09 PM »
Landry that is an old unit. Not sure it would be worth repairing. He needs to borrow somebody's spare transducer before he pays for a reworked unit. Bob
Offline chetmaychua
  • Software: 5.450
« Reply #4 on: September 24, 2015, 12:23:15 AM »
Thanks for your feedback.
I decided to buy a new transducer. I will try it this Sunday and let you know.
Humminbird XNT 9 SI 180 T Transom Mount Transducer
Could you confirm that this unit is a 'dualbeam"?
Thanks,
CMC
Offline bobcoy
« Reply #5 on: September 24, 2015, 08:03:07 AM »
yes,duel beam
« Reply #6 on: September 24, 2015, 12:08:27 PM »
"Dual Beam" is defined as a HB unit capable of transmitting 2 separate frequencies for the 2d sonar function ...
Like Bob mentions ...your 797 is capable of "Dual Beam" ...
As a sidenote ... "Dual Beam Plus" is defined as a HB unit capable of 2 separate frequencies for the 2d sonar function ... AND the capability to display those 2 frequencies separately or combined in 1 split sonar view or blended into one sonar view ...
« Last Edit: October 05, 2015, 12:09:53 AM by rnvinc »
Last post June 06, 2011, 10:45:08 AM
by Roddy
Last post September 04, 2012, 12:46:05 PM
Last post March 04, 2013, 12:47:30 PM
Last post June 09, 2013, 11:21:42 PM
by MTBob
Last post April 15, 2018, 10:13:41 PM
Last post April 28, 2020, 03:54:03 PM
