Author Topic: ONIX Power cord  (Read 10395 times)
Offline Thermite
  • Unit(s): Onix 10
ONIX Power cord
« on: August 28, 2015, 12:57:19 PM »
Currently my unit is wired to the fuse box at the console, we all know what that does to the unit each time you turn the key. I need to run wire back to the battery. Does HB make a power cord for the ONIX longer than 6' ? If not, what is the best way and what is the best material  to use?
Offline Whistler
  • Unit(s): 1198c SI, 1199ci, Helix 12 SI G2N
  • Software: 7.510,7.460,1.460
  • Accessories: Heading Sensor, NMEA
Re: ONIX Power cord
« Reply #1 on: August 28, 2015, 03:15:10 PM »
I don't know about the HB available Onix power cable, but what I have used for wiring directly to the battery, and this has worked really well for me, is a 12 gauge 10' - 25' extension cord from the local Walmart.  I just cut the ends off of it and strip two of the leads for my battery terminals.  This will give you 3 - 12 gauge stranded conductors in a single jacket which makes it really easy to pull and the 3rd conductor gives you a spare if you ever need it.
« Last Edit: August 28, 2015, 03:20:46 PM by Whistler »
Re: ONIX Power cord
« Reply #2 on: August 28, 2015, 11:02:17 PM »
HB would suggest 14 ... 12 is better ... I used 10 ...
Marine multistrand tinned is made for the vibration in marine environments ...
http://www.bestboatwire.com/marine-wire/marine-primary-wire
Don't forget the 5amp fuse close to the battery ...
« Last Edit: August 28, 2015, 11:05:24 PM by rnvinc »
Last post April 14, 2010, 04:00:55 PM
by salvor6
Last post August 11, 2012, 03:27:19 PM
by dubosegriffin
Last post March 04, 2013, 12:47:30 PM
Last post March 04, 2013, 03:22:29 PM
by KeggER420
Last post December 30, 2015, 12:01:28 PM
by bobcoy
Last post April 28, 2016, 01:29:40 AM
Last post November 28, 2019, 08:05:08 PM
Last post December 22, 2020, 09:38:16 PM
