Author Topic: Onix questions  (Read 9236 times)
Offline manac
  • Unit(s): 998c hdsi/ onix 10si
  • Software: 7.6 and 2.7
  • Accessories: pilot link ,AS ETH 5PXG
Onix questions
« on: August 20, 2015, 08:50:15 AM »
I have a couple questions that I can't seem to find the answer too , when using the autochart live feature and i record/map an area is there a setting I can't find that will put the depth numbers on the contours ? like a lake masters card does, all I get is lines and what highlights I put for different depths I was wanting to match some of the maps I previously made using my 998 .Will the AS GPS HS GPS receiver help give faster response time to whats happening on the map screen it seems like a very delayed response at times.
Re: Onix questions
« Reply #1 on: August 20, 2015, 08:18:09 PM »
The HS GPS will give you faster response to direction changes and display what direction the boat is pointing even sitting still.
The lack of depth markers is one of the things I think Humminbird needs to fix with Autochart Live.  I think the only way you can get the depth markers is to "overlay" it on a separate map card ..... You can adjust the transparency to see the mapping underneath ....I am not 100% sure, but I think this only works with a Lakemaster card.
It would be good to call customer service about this so they are hearing frustration about this from customers.
by Nitro78
Last post July 07, 2014, 10:43:13 PM
by CarolC
Last post July 16, 2014, 09:26:31 PM
by Thermite
Last post November 05, 2014, 04:09:24 PM
Last post March 10, 2015, 06:43:58 PM
Last post February 18, 2015, 11:48:46 AM
by brisner
Last post April 21, 2015, 10:23:09 PM
Last post May 06, 2015, 05:06:56 PM
