Author Topic: Helix 5 and 7 question  (Read 13184 times)
Offline Bruced
« on: July 13, 2015, 11:50:17 AM »
So I'm thinking about buying one of the two depthfinders listed and am wondering if my full sized sd cards will work in them somehow with some kind of adapter. Or do I have to toss them and buy the new micro cards? If they don't work  I'll probably keep the 798 that I have now.
Re: Helix 5 and 7 question
« Reply #1 on: July 13, 2015, 10:58:07 PM »
The Helix line are all micro SD Card ...
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #2 on: July 14, 2015, 08:26:49 AM »
your 798 has more optional features compare of the  Helix or 698 unit.
you wont see any changes switching to helix except the two extra inches ... which is not such a big deal ..
Offline Bruced
« Reply #3 on: July 14, 2015, 06:16:32 PM »
So I know the helix 7 takes a mini card. Just wondering if there's such a thing as an adapter to plug into the mini card hole of the helix 7 so that  I could use my full sized lakemaster cards into the adapter which is plugged into the helix 7. Just wanted to know if such an adapter exists.
« Reply #4 on: July 14, 2015, 10:33:19 PM »
I found this ...
 http://www.amazon.com/48cm-Sd-micro-Card-Extender-Cable/dp/B007WYRO7O
I have no idea if it will allow you to use your SD Card in a micro SD Card slot ...
It's pretty cheap ... Might be worth a shot ...
Let us know if you try it and it works ...
« Last Edit: July 14, 2015, 10:34:36 PM by rnvinc »
Offline Long Hair
  • Unit(s): LCR 2000, LCR 8000, Helix 5 SI GPS
  • Software: 7.260
  • Accessories: TM Transducer
« Reply #5 on: July 21, 2015, 11:18:15 AM »
The only downside of the cable extender, is that the little door on the Helix couldn't go back on. If the unit is exposed to a splash of water, that would be bad medicine for it. PS I already bought a new door for my Helix. That looks like it could get lost in a hurry and I want to have an extra.
You can always make too much, work.
Last post January 02, 2015, 08:59:09 PM
by Bayou Basser
Last post January 17, 2015, 09:53:51 PM
Last post April 14, 2015, 03:28:06 PM
by CATNIP
Last post July 16, 2015, 10:48:12 AM
by Beaulieu80
Last post December 23, 2015, 03:54:27 PM
Last post January 06, 2016, 09:46:14 PM
Last post February 15, 2016, 10:01:01 PM
Last post February 28, 2016, 10:15:36 AM
by N9Phil
