Author Topic: External GPS receiver for my 798ci hd si  (Read 20380 times)
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« on: July 06, 2015, 01:01:37 PM »
is there a way to get a list of all external gps receivers compatible with my unit from all brands?
Re: External GPS receiver for my 798ci hd si
« Reply #1 on: July 06, 2015, 01:03:59 PM »
The 798 will be compatable with pretty much all the Humminbird GPS models, but the  AS GRP and heading sensor models are software revision dependent.
Offline Beaulieu80
  • Software: 7.68
« Reply #2 on: July 07, 2015, 11:04:09 AM »
On humminbird website there is no list with compatible units how can I confirm it is the receiver AS GPS HS is compatible or not ?
« Reply #3 on: July 07, 2015, 11:16:51 AM »
I think it is compatible with any Humminbird unit that accepts external GPS .... and has greater than 6.57 software release.
« Reply #4 on: July 07, 2015, 11:07:45 PM »
http://www.humminbird.com/Products/798ci-HD-SI-Combo/
Display Size - Diagonal:5"
Display Pixel Matrix:640V x 640H
Display Type:Color TFT
Display Colors Grayscale:256 Colors
Sonar Standard:Side Imaging/Down Imaging/DualBeam PLUS
Standard Sonar Coverage:20°, 60° & 180° @ -10db
Standard Sonar Frequency:200/83/455 kHz
Sonar Optional:QuadraBeam PLUS
Target Separation:2.5"
Power Output RMS:500 Watts
Power Output Peak to Peak:4000 Watts
Depth Capability:100 ft (SI/DI), 1500 ft
Temperature:Built In Transducer
Speed:GPS Speed Included
Backlight:Yes
Unit Size - Gimbal Mount:6.9"W x 7.5"H x 4.5"D
Mount A Type:Quick Disconnect
Unit Size - Indash Mount:6.9"W x 5.4"H x 1.25"D
Mounting Options:Quick Disconnect/Optional In-Dash Mounting Kit
Transducer Standard:XNT 9 SI 180 T
Transducer Mounting:Transom
Power Input:10-20 VDC
Power Draw:615 mA
GPS Receiver:Included
GPS Tracking:Included
GPS Chartplotting:Included
Waypoints, Routes, Tracks/Points:2,750, 45, 50/20,000
Humminbird Mapping:Optional
Navionics Gold/HotMaps:Optional
Navionics Platinum+:Not Supported
Platinum Capable:Not Supported
C-Map 4D:Not Supported
360 Imaging:Optional
i-Pilot Link:Optional
HD Radar:Not Supported
NMEA 2000:Optional
5 Port Expansion Module:Optional
WeatherSense:Not Supported
Precision GPS:Included
Heading Sensor GPS:Optional
PC Connect:Optional
External GPS Receiver:Optional
AS Interlink:Not Supported
AIS Compatability:Not Supported
SwitchFire Sonar:Included
Screen Snap Shot:Included
Sonar Recording:Included
Upgradable Internal Software:Included
Split Screen Zoom:Included
Split Screen Bottom Lock:Included
3D Chart View:Included
Large Digits View:Included
Wide/Narrow Cone Split Screen:Included
Custom View Selections:Included
Custom Digital Readout:Included
View Preset Keys:Included
Temperature Graph:Not Supported
Temperature Alarm:Included
Freeze Frame:Included
Instant Image Update:Included
Mark Structure on Sonar:Included
Selective Fish ID+:Included
Real Time Sonar:Included
Triplog:Included
X-Press Menu System:Included
Card Reader Available:Yes
# Card Slots:2
Bob is correct ... You will need at least 6.570 to recognize the AS GPS HS antenna ...
« Last Edit: July 07, 2015, 11:15:19 PM by rnvinc »
Offline Beaulieu80
  • Software: 7.68
« Reply #5 on: August 07, 2015, 02:31:29 PM »
what is best between AS GRP and heading sensor ?
what more the heading can do to my unit fro that 130$ extrat$$  ?
« Reply #6 on: August 07, 2015, 09:52:36 PM »
The AS GPS HS antenna has an internal magnetic compass that will show the boat's orientation (which way the bow is pointing) on the chart view at all times ...even while stationary ...
Here is my write up ...
http://forums.sideimagingsoft.com/index.php?topic=5109.msg32045#msg32045
« Last Edit: August 07, 2015, 09:54:12 PM by rnvinc »
Offline Beaulieu80
  • Software: 7.68
« Reply #7 on: August 08, 2015, 11:59:16 AM »
Where can i see the specps and gps speed ? compare to my 798si combo
« Reply #8 on: August 09, 2015, 12:35:56 AM »
I'm not sure if this is the info you are looking for ...
AS GPS HS antenna (user manual at the bottom of this page)..:
http://www.humminbird.com/Products/AS-GPS-HS/
AS GRP antenna (user manual at the bottom of this page) ...:
http://www.humminbird.com/Products/AS-GRP/
Offline Beaulieu80
  • Software: 7.68
« Reply #9 on: August 09, 2015, 08:36:20 PM »
no, i wanted to have more technical specs like antena speed, we dont see those compare to other brands
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #10 on: August 09, 2015, 09:22:33 PM »
What speed are you looking for? Are you meaning a maximum sample rate? I think the "HS" may be capable of a higher rate but the unit has to be able to compute those samples faster to make use of it. I doubt you will be able to get better performance than your GRP. The Heading sensor (digital compass) will keep your boat icon pointed at slow speeds with less lag than just the GPS heading. That is the only advantage you will get. It is your $130 you will have to decide if it is worth it to you and your fishing style. Bob
« Last Edit: August 10, 2015, 08:25:58 AM by bobcoy »
Offline Beaulieu80
  • Software: 7.68
« Reply #11 on: August 10, 2015, 09:01:19 AM »
I mean. if my unit has 5hz gps speed and external puck has 10hz speed. then i will get a bonus speed. thats why i wanted to know the specs
« Reply #12 on: August 10, 2015, 09:23:59 PM »
Let me see if I can get Deb to offer some info for you ...
Last post May 19, 2010, 09:22:08 AM
Last post May 27, 2010, 04:31:13 PM
Last post September 04, 2013, 08:34:32 AM
Last post November 05, 2013, 08:54:02 AM
Last post November 19, 2014, 06:15:07 PM
by kosmo
Last post January 28, 2015, 03:58:14 PM
by Brunswick
Last post June 22, 2015, 03:18:23 PM
Last post July 12, 2015, 10:37:46 PM
