Author Topic: How to download data from my device when it is not mounted in the boat?  (Read 14886 times)
Offline Kees Michielsen
  • Boston Whaler Montauk fanatic
  • Unit(s): Helix9 G4N / HB998cx Si
  • Accessories: Autochart pro
I left my boat for another holiday in Denmark.
I took my 998 home.
I trie to download the data from my last fishing trip to my SD card and then to my laptop but I can't save the data on the SD card, that menu option I can't find..
I have a spare power cable to connect the 998 to a accu.
Anybody an idea how I can retrieve the data from the device?
(English is not my first language, sorry for any mistakes  8) )
« Last Edit: June 08, 2015, 02:32:30 PM by delta1017 »
Under your NAV menu, you should see an Export
option.
It may under a sub menu titled Waypoints/Routes/Tracks.
That will save to the SD card.
« Last Edit: June 08, 2015, 11:08:04 AM by ITGEEK »
I don't see the waypoints under the NAV menu, either the export option  ???
Make sure you are using the advanced settings.
According to the 998c owners manual,
press the right cursor key, and follow instructions.
I'm sorry but in advanced mode I still don't see in the menu where I can save data to the SD, I even don's see waypoints.
When I press the MARK button I get the message that GPS receive is neccessary.
I only have a powerd cord attached, the rest is on the boat in Denmark and I am in Holland...
I would say to consult your owner's manual.
Somebody else with a 998c may also chime in.
Last resort, call Humminbird Customer service.
Thx ITGEEK,  You had the solution  ;D
I had to put the unit in advanced settings but also in DEMO mode
(I had NORMAL mode 8) )
Now I could save the navdata to the SD card, THX for your help!!
 :D :D :D
Offline Bubba Canuck
  • Unit(s): 1199ci HD SI / 999ci HD SI / 597ci HD DI
That's a handy trick. I'll have to remember that.
There are times when I'm learning / testing my unit in my office with a portable battery (but no transducer or iPilot connected) so I can't see certain menus.
14' Lund "Tin Can", 25 hp Merc: $3,000
Humminbird 1199 CI HD SI Combo, Minnokota Terrova with iPilot Link and AutoChart Pro: $5,000
Humminbird 597 CI HD DI Combo: $600
Reaction from other Boats when Fishing: PRICELESS
The reason for this is in Normal mode, the unit must wait until the GPS antenna connects to the satillites before the unit will even show the Chart and NAV tabs ...
In Simulator, the unit will faux a connected GPS antenna ...which allows the unit to show the Chart and NAV tabs ...
Last post May 31, 2012, 05:29:15 PM
by Ricky
Last post September 20, 2012, 02:41:28 PM
Last post January 25, 2015, 03:18:20 AM
by matt@reefmaster
Last post September 03, 2014, 09:59:11 PM
by Smellybox
Last post October 28, 2014, 08:46:28 AM
Last post September 09, 2018, 04:29:40 PM
by wapati
Last post July 07, 2019, 08:56:48 AM
by strokerace
Last post August 20, 2019, 05:44:24 PM
