Author Topic: 698 SI surface clutter  (Read 10381 times)
Offline Buzzy McGraw
  • Unit(s): 698ciHD SI KVD
« on: June 08, 2015, 08:24:05 AM »
Moved
Having the same problem with my 698 SI. It didn't have a problem the first couple times out but is doing it now. Motor on/off trimmed up/dn doesn't matter. Different water didn't change. I noticed yesterday that it has 2 distinct lines on right side now. Unit is only 2 wks old. Transducer problem?
Re: 698 SI surface clutter
« Reply #1 on: June 08, 2015, 08:29:35 AM »
Can't post any pics. Tried the same pic as previous post and says its too large?!
« Reply #2 on: June 10, 2015, 11:33:18 PM »
Try using photobucket for posting pix ...
And pix of your xducer install would be beneficial ...
« Reply #4 on: June 12, 2015, 06:18:41 PM »
« Reply #5 on: June 12, 2015, 06:20:57 PM »
Ahh. I figured out the pics! ;D
« Reply #6 on: June 12, 2015, 06:23:10 PM »
« Reply #7 on: June 12, 2015, 10:37:31 PM »
It's picking up the Outboard mount and the toon on the other side ...
The SI beams reach all the way up to the water's surface left and right ...
You can verify this by removing the xducer and sticking it farther down in the water on a stick or pole of some sort ...
Pontoon installations benefit from dual SI xducer setups with the AS SILR Y cable ...
http://www.humminbird.com/Products/AS-SILR-Y/
« Last Edit: June 12, 2015, 10:40:40 PM by rnvinc »
Last post June 19, 2012, 10:13:05 AM
by sjefsrafsern
Last post August 20, 2013, 03:53:14 PM
Last post January 11, 2014, 10:18:39 AM
Last post April 07, 2014, 02:56:20 PM
Last post April 13, 2015, 08:31:54 AM
Last post April 13, 2015, 06:35:23 AM
by bobcoy
Last post May 06, 2015, 12:35:08 PM
Last post June 05, 2015, 10:59:47 PM
