Author Topic: Fixed - Installer Error was (New install, Doesn't see GPS)  (Read 10393 times)
Offline Stymie
  • Unit(s): 898, 898
  • Software: Latest
  • Accessories: XM Weather, TM 360, AS GPS HS
« on: March 10, 2010, 12:53:53 AM »
Hey everyone,
Just installed the bow mount 898 tonight.  Went into System Status screens and it did not see the GPS.
The GPS is connected to the NMEA portion of the Y-cable and my Interlink is connected to the ACCY portion of the Y-cable.
It sees the Interlink module but does not see the GPS puck.
Any suggestions?
« Last Edit: March 12, 2010, 09:22:21 PM by Stymie »
Offline Chiboo
  • SpearFishing
  • Unit(s): Solix 10 MSI+ G3
  • Software: 4.130
Re: New install, Doesn't see GPS
« Reply #1 on: March 10, 2010, 02:09:57 AM »
Hy Stymie.
Try to attach GPS module directly without a Y-cable and look that will be. Either contacts, or the module.
« Reply #2 on: March 10, 2010, 01:20:47 PM »
What Chiboo said plus make sure that your boat is outside so the GPS Receiver has a clear view of the satellites.
If it still does not work than see if you can find someone else with a Humminbird and test your unit with their GPS Receiver.
Offline Stymie
  • Unit(s): 898, 898
  • Software: Latest
« Reply #3 on: March 11, 2010, 12:45:57 AM »
Thanks for the suggestions. It was just a loose connection at the connector, apparently it had backed off somehow when I put it together.  All is well now.
Also, just wanted to mention that this thing sees the satellites in my garage with the garage door down.
Now ain't that cool!
I'll be heading out to the water tomorrow to check it out.
« Reply #4 on: March 11, 2010, 08:04:32 AM »
the GPS is great.  I can see the satelites in our shop and it has two stories above it.  In the past the lowrance unit would or could lose GPS when going under trees that were leaved out.  I have not seen this with the HB.  HB is on track for a pat on the back.   Chuck
Offline Singleshot
  • Unit(s): 798c Si
  • Software: 4.780
  • Accessories: n/a
« Reply #5 on: March 11, 2010, 09:02:13 AM »
I'm there with you sonar2k, I just powered my 798 up in my garage where my Lowrance lgc3k wouldn't lock my HB was on.
JIM
To ignore the facts does not change the facts.
Last post December 17, 2009, 11:37:18 AM
Last post September 28, 2010, 12:47:04 PM
Last post January 31, 2011, 01:31:22 PM
Last post August 12, 2011, 09:25:00 AM
by jimf
Last post October 26, 2011, 10:26:48 AM
by Solowolf
Last post March 31, 2013, 11:36:48 AM
by Coomdaddy
Last post May 27, 2013, 10:05:09 PM
by promapper
Last post April 28, 2020, 03:54:03 PM
