Author Topic: LakeMaster AC data for handheld GPS?  (Read 9387 times)
Offline iceperch
  • Unit(s): Helix 5, heix/solix 10 in future
« on: May 19, 2015, 02:19:58 PM »
Is that possible? During ice fishing handheld gps is more cmofortable for spot searching. Output format data working with this?
Offline mike82
  • Unit(s): 998 HD SI, 597 HD DI
  • Software: 7.090
  • Accessories: ipilot link
Re: LakeMaster AC data for handheld GPS?
« Reply #1 on: July 05, 2015, 09:51:51 PM »
I looked all over for this last winter and found nothing. Hopefully they make something so we can use out auto chart maps on a handheld instead of lugging around our big open water units.
Offline iceperch
« Reply #2 on: July 06, 2015, 03:32:48 AM »
Reefmaster exported files to Google earth overlays, so with some smartphon with GPS it's possible to use, but it's low accuracy - dependend on smartphon's antenna.
Offline BobGinCO
  • BobGinCO
  • Unit(s): 385ci
  • Software: 6.110
  • Accessories: AutoChart
« Reply #3 on: July 09, 2015, 10:27:19 AM »
I would guess that most smartphone GPS accuracy is as good as my Humminbirds.  Accurate GPS is no longer technologically difficult.  It's almost to the point of questioning why I have a handheld GPS any more.
Live at 9,000 feet elevation.
Boat at 7,500 feet elevation...
Where my Merc 115 generates about 91.5 HP...
Offline CamoHunter
« Reply #4 on: July 09, 2015, 03:09:59 PM »
Yes, it is possible.  Sort of.  It's a work around, rather than an actual background map.  Meaning, the contours will be displayed as gps paths, rather than a background map.
I'll have to look at the program again to remember how I did it though.  In AutoChart, there is a way to export contours as .ht humminbird tracks.  You could then open that .ht file in GPSBabel, and convert those tracks to other GPS formats, such as .gpx which is widely accepted by most handheld gps units.
Or, you could just do what I do, and use my 788ci HD for ice fishing.
Offline iceperch
« Reply #5 on: July 10, 2015, 09:42:29 AM »
Thanks for Your reapley. I've got helix 5 si, but weight - 7Ah battery, unit &cable - its around 6kg. I'ts too much for my back ;) and I do not know how tempereture freeze lcd display- my older sonar were damaged  by frost and I'm trying be carefully.  For now I preparing my custom maps, if winter com - I'll try spot -fishing.
Last post April 10, 2010, 05:12:18 AM
by keizerh
Last post March 20, 2013, 12:30:05 PM
Last post November 20, 2013, 05:27:51 AM
by lars
Last post January 31, 2014, 04:05:30 PM
by Kountrykool
Last post April 15, 2014, 02:29:24 PM
by scgmc
Last post February 26, 2015, 06:25:45 PM
by SkeeterMatt
Last post April 23, 2015, 11:10:06 AM
Last post May 21, 2015, 10:47:51 PM
by Tamnud
