Author Topic: What size battery needed for 150 motor and electronics  (Read 11021 times)
Offline Jimmy B
  • Unit(s): Onix 8 SI Onix 8
  • Software: 6.3.0.0
  • Accessories: 360 Ulterra
« on: April 28, 2015, 03:13:17 PM »
Currently having problem with onix unit shutting down when engine is started, bought boat used and has a marine dual purpose battery rated at 625 cranking amps and 120 reserve capacity minutes. Looks like bigger battery would fit in compartment. What size battery should I use. Thanks.
Jim
Re: What size battery needed for 150 motor and electronics
« Reply #1 on: April 28, 2015, 04:25:42 PM »
I don't know about the battery Jim but part of the issue could be in the wire gauge sized used to go from the cranking battery to the power cable for the ONIX unit or even in the connections between the power cable and the battery.  Anything loose, corroded or even of a small wire gauge size (relative to the length of the wires) will restrict the amount of power that flows to the ONIX unit.  So i would look at possibly running new wires for the ONIX (with a new fuse and fuse holder) as well as replacing the battery.
How far do you have to extend the power cable for the ONIX so that it reaches the battery?
Offline Jimmy B
  • Software: 6.3.0.0
« Reply #2 on: April 28, 2015, 04:35:41 PM »
Just ordered 10/2 wire from west marine to go from battery to accy switch breaker, extended front Onix wires about 8 feet and nothing on console unit. I question the bigger the battery the better, it's just money. Thanks
« Reply #3 on: April 30, 2015, 08:57:42 AM »
Jimmy,
I would suggest hooking your sonar to a completely separate battery.
It can be a small battery.  Under power, you could get sonar interference from the main motors alternator.  Also, keep the sonar wires away from other wires and electrical devices.
Offline Boblagio
  • Unit(s): 899ci HD si, Matrix 37, 570di
« Reply #4 on: May 10, 2015, 01:44:22 PM »
ITGEEK, so if I hook my sonar (Model 899) up to a separate battery, since it's not being charged throughout the day by the main motor, I'm guessing that the draw is so low, that it will last all day? And, I would just charge the sonar's battery after a day of fishing like my trolling motor batteries?
There's no more room in my bilge area for another battery, but I think I have room under my console to put a battery.
« Reply #5 on: May 10, 2015, 07:52:33 PM »
Yes, that is correct.
Last post April 15, 2009, 10:01:32 PM
Last post March 06, 2010, 08:28:51 PM
by George
Last post June 17, 2010, 02:36:36 PM
by RzorbackAngler
Last post March 06, 2011, 03:53:18 PM
by Doc Stressor
Last post March 14, 2012, 11:15:55 PM
by nhealy
Last post January 10, 2013, 05:38:13 PM
Last post February 24, 2014, 07:46:07 PM
Last post July 21, 2015, 10:07:55 PM
by ESOXseeker
