Author Topic: 999hdsi and lowrance hdi5  (Read 10060 times)
Offline bassmasterG13
  • Unit(s): 999ci hd si combo
« on: April 28, 2015, 01:35:24 PM »
hello everyone I have a 999hd si mounted on the transom of my bass tracker. I recently added a lowrance hdi5 to my trolling motor for the bow. Every once in a while my hummingbird goes out of wack and reeds 400+ feet with stuff all over the screen. I don't know if I am cross talking sonar on the units or what. Did this happen to anyone and is there a way to set up both units so they don't cross talk, if that is infact what you think is happening?
Thanks Gio
Re: 999hdsi and lowrance hdi5
« Reply #1 on: April 28, 2015, 01:40:32 PM »
Gio,
I am assuming that the other unit is using 200kHz as well?  You should be able to check this yourself.  If so, you are probably getting some sonar cross-talk (interference).  Try turning on and up the Noise Filter menu on your 999 unit and see if that helps.
« Reply #2 on: April 28, 2015, 01:43:18 PM »
I can set the other unit to anything but yes I think it is on 200khz. Should I change that frequency or just try to turn up the noise filter ?
« Reply #3 on: April 28, 2015, 02:10:21 PM »
I would change the frequency if you can.  Otherwise the Noise Filter may be filtering out some of the weaker sonar signals that you want to see on your 999 unit.
« Reply #4 on: April 28, 2015, 02:39:53 PM »
what do you recommend turning the frequency on the lowrance to ? Am I only getting cross talk because its not 2 humminbirds?
« Reply #5 on: April 28, 2015, 04:18:57 PM »
I have no idea what frequencies the Lowrance unit is capable of.
You are not getting cross-talk because of the brand(s) of sonar units you are using.  You are getting cross-talk because you have more than one sonar unit transmitting and receiving sonar at the same frequency as another sonar unit and the sonar beams are overlapping.
« Reply #6 on: April 28, 2015, 04:24:23 PM »
ok i have my hbird setup on beam select 200/83 kHz and my frequency on 455 kHz which is recommended for best readings correct? i will just setup the lowrance on something different and hopefully not get the cross talk
« Reply #7 on: April 28, 2015, 04:27:10 PM »
Depending on how you are using your 2D sonar I might set it to only use the 200kHz frequency.
Last post September 08, 2010, 09:19:24 AM
by bamafish
Last post June 01, 2012, 09:43:24 AM
Last post May 09, 2017, 06:34:41 AM
by Rickard
Last post September 02, 2013, 04:39:29 PM
by DiveExplorer
Last post July 03, 2013, 10:43:55 AM
by PaulB
Last post January 16, 2014, 02:57:28 PM
by hgv
Last post June 09, 2015, 06:50:21 AM
by Silviu
Last post March 24, 2015, 10:42:01 AM
by Have Rod, will travel
