Author Topic: Ferrite ring size  (Read 8831 times)
Offline Planokeith
  • Unit(s): Helix 12 MEGA SI Gn2, Helix 7 CHIRP Gps
  • Software: 1.61 , 1.65
Ferrite ring size
« on: March 25, 2015, 03:12:14 PM »
Hey Gang,
I was curious does it matter what size a ferrite ring you use to wrap the transducer cable around? Would a larger ring than what hummingbird sent me work since they say the more wraps the better ?
I was only able to get 5 wraps on my old transom transducer on my 959 DI with the ring hummingbird sent me . I installed my new XTM 9 WIDE DI 20 T. on my i pilot Which has a thicker cable ( Because of extra shielding ) and i don't think i will be able to even get 5 this time. I have improvement with my RFI noise with the new transducer but i have to adjust the unit in different depths of water. But it is still there.
Any way hopefully some one can answer
Thanks in advance
Keith
Re: Ferrite ring size
« Reply #1 on: March 25, 2015, 03:25:24 PM »
I don't know if a different size would matter unless it has something to do with the frequency it works at - which does make a difference.  This is why you should use the ferrites from Humminbird and not from somewhere else.
Offline Planokeith
« Reply #2 on: March 25, 2015, 03:28:41 PM »
Okay Greg thanks
 Keith
Offline Planokeith
« Reply #3 on: March 25, 2015, 03:40:22 PM »
One more question maybe need to call HB , but do they just make one size ring? I watched a video of Doug V and he was able to get 7 wraps and there was no way i could have gotten seven. And now with the thicker cable i know there is no way.
« Reply #4 on: March 25, 2015, 03:47:19 PM »
Just the one ring size that I am aware of.  A thicker cable would take up more space which would mean fewer wraps do to the connector size not fitting through the smaller opening with the larger diameter cable.
Offline Planokeith
« Reply #5 on: March 25, 2015, 04:01:15 PM »
Okay Thanks Greg i will use the one that hummingbird sent me
 Keith
Last post February 05, 2011, 12:03:15 PM
by stillbear
Last post February 11, 2011, 11:24:32 AM
by mendota
Last post March 06, 2011, 03:53:18 PM
by Doc Stressor
Last post December 20, 2011, 05:07:20 PM
by sneakypete
Last post June 16, 2011, 01:47:15 PM
Last post January 14, 2012, 02:33:26 PM
by ecduzitgood
Last post March 24, 2013, 04:58:03 PM
by Submaster
Last post February 19, 2014, 12:42:15 PM
