Author Topic: 1199 on ranger 519  (Read 7804 times)
Offline Ringgoldranger
  • Unit(s): 1199
1199 on ranger 519
« on: March 21, 2015, 04:00:39 PM »
Dealer tels me you can't just use the one transducer on the transom and be able to read regular sonar while on plane. Is this accurate ? Anyone on here have any pics of transducer install on ranger?
Re: 1199 on ranger 519
« Reply #1 on: March 22, 2015, 01:39:58 AM »
It is entirely possible to mount the SI xducer low enough on the transom to get readings at high speed ...several are using this very setup ... But ...
Most high performance boat hull owners opt for the XP 9 20 And the AS SIDB Y for high speed depth readings ...
This is because these type hulls rise out of the water when on plane ...With nothing but a small "pad" of the rearward underside boat hull touching the water ...
This makes it difficult to find an optimum mounting spot on the transom that will keep the SI xducer in the water ... While the boat is no longer down in the water ...
As long as any xducer is in clean bubble free water ...sonar (any type) will work ...
Get air between the xducer face and the water ... No sonar reading ... Any brand ... Any model ... Any housing shape ...
Sonar will not work thru air ...It's that simple ...
To get the SI xducer down into the water while the hull is up on plane would require mounting the xducer below the bottom of the hull line ... This makes the $270 SI xducer susceptible to being damaged from water borne debris or obstacles that can rip that $270 xducer right out of your pocket book ...
This is why most opt to mount the SI xducer higher on the transom for idle speed scanning ... And then use the bilge mounted XP 9 20 with the AS SIDB Y cable for on plane depth readings ...
« Last Edit: March 22, 2015, 03:19:15 AM by rnvinc »
  • Unit(s): 1199
« Reply #2 on: March 22, 2015, 06:14:18 AM »
I can't thank you enough for that explanation. I'm assuming the 2 new 1199's I have coming will not come with this transducer or cable. I will call and order these on Monday.
Last post January 09, 2010, 10:20:21 PM
by Pmcclung
Last post February 24, 2012, 01:32:15 PM
Last post December 12, 2012, 03:45:08 PM
by nite owl
Last post May 03, 2013, 10:00:20 AM
Last post January 31, 2014, 10:00:07 AM
Last post March 20, 2016, 11:11:47 PM
Last post March 06, 2017, 07:18:36 PM
by hutcher1
Last post June 19, 2018, 06:34:58 PM
by Seabee
