Author Topic: 1198cx si  (Read 5895 times)
Offline metalworx
  • Unit(s): 2- 998c si
  • Software: 6.740
1198cx si
« on: March 20, 2015, 09:29:47 AM »
Question for all you electronics gurus!   I have the above mentioned unit.  If I were to put a dedicated di transducer on this unit with the switch,  will I get down image as good as a di unit? If so, thinking about putting a di transducer on and bow 360.  Will this work? Thoughts.............
Re: 1198cx si
« Reply #1 on: March 20, 2015, 09:59:07 AM »
Yes it will work but I don't know how well the Di sonar will show.
Re: 1198cx si
« Reply #2 on: March 21, 2015, 02:10:48 AM »
With a DI xducer on a HB SI unit ...
Will you get as good of DI as a dedicated DI unit ??... No ... Different DI processing algorithms ...
Will you get better DI than the stock "DI from SI" ...?? Absolutely ... Because the piezo will be pointing straight down ...
Brushpile with "DI from SI" processing ...(on my 1197c SI) ...
Same brushpile with XTM 9 WIDE DI 20 T ... (On my 1197c SI) ...
« Last Edit: March 21, 2015, 02:13:05 AM by rnvinc »
Last post March 21, 2014, 11:16:42 AM
Last post December 27, 2014, 03:33:22 AM
by pachedu
Last post July 18, 2018, 06:35:29 PM
