Author Topic: AS-SIDBY-Y Loose?  (Read 9419 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
AS-SIDBY-Y Loose?
« on: March 11, 2015, 04:55:59 PM »
I just ran the transducer cable for glassing in a puck. I connected the 998 si transducer and the puck transducer tothe SIDBY man it seems loose, I am afraid they will vibrate loose! Is this normal?
Re: AS-SIDBY-Y Loose?
« Reply #1 on: March 11, 2015, 06:42:28 PM »
It takes a pretty good push to get the 9pin connectors popped together ...(and even greater force to disconnect them) ...
There should be small square tabs on the left and right outside of the male "house shaped" connector ... And matching square holes in the female connector ...
The 2 connectors must be pushed together until these tabs pop into place for a full connection ...
« Last Edit: March 11, 2015, 06:44:11 PM by rnvinc »
Offline 6speedy3
« Reply #2 on: March 11, 2015, 06:45:49 PM »
Thanks, I haven't pushed until it snaps, I will do that, thanks again.
« Reply #3 on: March 12, 2015, 04:09:54 PM »
Before getting too rough with what you already have ...
Pull the connections back apart and inspect the gold pins in the connector to make sure they all still look straight ...
A bent pin would cause difficulty like you experienced ...
« Reply #4 on: March 12, 2015, 04:20:46 PM »
That's a very good point Rickie.
Last post January 07, 2011, 02:59:21 PM
by MonteSS
Last post October 15, 2012, 04:34:35 PM
Last post March 29, 2013, 01:03:04 PM
by Rough House
Last post August 02, 2013, 11:16:29 AM
by tanman
Last post May 17, 2013, 07:14:24 PM
by supernukes
Last post March 18, 2016, 12:08:42 PM
by RonnieB
