Author Topic: 7.51 update issue  (Read 11602 times)
Offline Trytoofish
  • Software: 2.0, 7.51,
7.51 update issue
« on: March 07, 2015, 08:01:39 AM »
I just updated 2 humminbird  998 hd units to 7.51 the update seemed successful but when i restart and go to simulator there is no 83 khz even after I switch to only 83 in transducer select. I also noticed that there is no "encrypt sd" option as needed for chart select. anyone else do the update? What do you see?? ITS Highly unlikely the same glitch would happen twice. it must be an update issue!!
Try Too Fish  Forced To Work
Offline Trytoofish
Re: 7.51 update issue
« Reply #1 on: March 07, 2015, 08:22:19 AM »
well the encrypt issue resolved itself after i restarted the second time, but the 83 still doesn't show.
Offline Trytoofish
« Reply #2 on: March 07, 2015, 08:29:48 AM »
The Encrypt menu, I just discovered you need to have a card in the slot or the option don't show so it may have been working all the time
« Last Edit: March 07, 2015, 08:38:53 AM by Trytoofish »
« Reply #3 on: March 07, 2015, 08:51:17 AM »
The simulator is an "on the water" recording captured by Doug V ...and then hard coded into the unit ...
Doug forgot to turn on the 83kHz ...therefore the 83kHz was not recorded for the Simulator recording ...
Offline Trytoofish
« Reply #4 on: March 07, 2015, 08:59:26 AM »
Well that explains it. I guess I don't have any issues that I'm aware of. but will be a month before the ICE is gone. Thanks Rickie. I dont know why I never noticed it before. I guess with all the talk about 83Khz I had to check it out
Offline navionic
« Reply #5 on: March 07, 2015, 03:17:58 PM »
Greg said recently that it was done because of the space-saving memory unit.
On the water at a frequency of 83 kHz readings are normal. But blue fish FishID  mode still no :(
« Last Edit: March 07, 2015, 03:19:25 PM by navionic »
« Reply #6 on: March 09, 2015, 10:48:38 AM »
I'm seeing mixed Orange and Blue Fish ID Symbols on my 998c SI unit once I updated it to the 7.510 software.  This is while viewing the Simulator mode.  The older 998c Si units (not the 998c HD Si models) had both 200kHz and 83kHz sonar data in the simulator.
Offline navionic
« Reply #7 on: March 09, 2015, 12:00:19 PM »
Hmm. Blue symbol is not observed in 899с 7.460 software
Last post November 20, 2009, 09:37:27 PM
by harry padgett
Last post March 07, 2011, 06:22:00 AM
by stillbear
Last post March 11, 2011, 08:37:06 AM
Last post December 12, 2011, 05:14:01 PM
Last post April 15, 2014, 05:25:41 AM
by Skot
Last post July 08, 2014, 01:05:24 PM
by Bobbylove
Last post April 10, 2015, 03:13:05 PM
by 4d-rock
Last post June 17, 2015, 09:35:01 PM
