Author Topic: Using adapter cables AD 1429 and Y cable AS 14 SI DB Y  (Read 12608 times)
Offline Trytoofish
  • Software: 2.0, 7.51,
« on: February 26, 2015, 08:13:46 AM »
On my terrovia It looks like using the AD1429,and the Mkr us2 13 and the y cable AS 14 si db y should allow using both the us2 for 2d and the older 9 pin hdsi on a Onix. The cable of the 14 pin transducer wont fit the groove on the terrova and I dont want to go back to the coiled cable mess of the old days. Will I have 2d si and di with this configuration?
Try Too Fish  Forced To Work
  • Moderator
Re: Using adapter cables AD 1429 and Y cable AS 14 SI DB Y
« Reply #1 on: February 26, 2015, 12:39:12 PM »
That is what it looks like to me too though I do not know of anyone who has tried it.
« Reply #2 on: February 26, 2015, 05:51:30 PM »
I also have not seen nor heard of anyone using the core unit XHS 9 HDSI 180 T on the Onix ... Even tho that option is possible according to the literature for the AD 1429 ...
This is on my list of tests in the coming months ...
You may be interested in this from the verbiage ...
If you use this adapter with the XHS 9 HDSI 180 T, you will lose Down Imaging sonar.
http://www.humminbird.com/Products/AD-1429/
Meaning the XHS 9 HDSI 180 T has no dedicated DI piezo for the Onix to transmit DI thru ...
« Last Edit: February 26, 2015, 05:52:58 PM by rnvinc »
Offline Trytoofish
« Reply #3 on: February 26, 2015, 06:17:27 PM »
Thanks Rickie
 I was hoping the Onix could make a composite DI like the core units. but maybe not!
Offline Redbad
  • Unit(s): Onix 10CXI SI - Helix 12Chirp Mega G2N
  • Accessories: AS 360 TM DrDepth AutoChart Pro ReefMast
« Reply #4 on: February 26, 2015, 07:04:36 PM »
Hi all,
I have since a month an Onix and use the XHS 9 HDSI 180 T with the adapter cable.
3 weeks ago I made the first recordings in record mode and snapshot.
My first goal was to look at the SI and 360 TM, but maybe I can playback(upcoming weekend) the record at the Onix and see what has done the DI.
When I know more, I'll send a print screen.
Annexed is a snapshot in SI of a wooden wreck.
greeting Bert
« Last Edit: February 26, 2015, 07:19:51 PM by Redbad »
Offline Trytoofish
« Reply #5 on: February 26, 2015, 07:15:39 PM »
Thanks for posting  Redbad Let us know. Thats a very nice image in my opinion
« Last Edit: February 26, 2015, 07:17:42 PM by Trytoofish »
« Reply #6 on: February 27, 2015, 11:09:00 AM »
Thanks Rickie
As I mentioned the Onix can't transmit DI thru the XHS 9 HDSI 180 T because the XHS 9 HDSI 180 T does not have a DI piezo ...
And the Onix can't display the "blended DI from SI" because Onix doesn't have programming for this task ...
It would be best to turn off the DI ping in the Onix when connected to the XHS 9 HDSI 180 T to keep the Di transmitter in the Onix from transmitting ...
« Last Edit: February 27, 2015, 11:11:00 AM by rnvinc »
Last post June 12, 2009, 08:36:47 AM
Last post February 11, 2011, 03:39:10 AM
by Rüdiger
Last post June 14, 2012, 12:13:15 PM
Last post October 25, 2012, 04:40:24 PM
Last post August 01, 2013, 01:17:13 PM
by Gillfisher
Last post March 06, 2014, 01:25:57 AM
Last post April 02, 2015, 11:16:13 PM
