Author Topic: Helix 5 DI GPS  (Read 26821 times)
Offline sniper
  • Unit(s): 598 ci hd si
Helix 5 DI GPS
« on: February 06, 2015, 07:37:20 PM »
Just got the helix 5 di gps unit for using on trolling motor anyone here using this setup
Offline PAPA BEAR
  • Unit(s): HB 899 & Helix 5 di
Re: Helix 5 DI GPS
« Reply #1 on: February 06, 2015, 09:21:23 PM »
Just picked up one today. I have a Helix SI mounted on the dash and going to put the DI up front and transducer on trolling motor.  Let us know how yours works out.
Re: Helix 5 DI GPS
« Reply #2 on: February 09, 2015, 03:56:42 PM »
Welcome to the Humminbird Side Imaging Forums sniper and PAPA BEAR.
Be sure to be the first to post some screen snapshots from your HELIX 5 units!
Offline PAPA BEAR
Re: Helix 5 DI GPS
« Reply #3 on: February 09, 2015, 04:56:40 PM »
Used them today for a short time. Here is a shot from the SI
Re: Helix 5 DI GPS
« Reply #4 on: February 09, 2015, 07:06:42 PM »
Used them today for a short time. Here is a shot from the SI (Attachment Link)
That cursor needs a crappie stakebed under it on that underwater hump ...
Offline PAPA BEAR
Re: Helix 5 DI GPS
« Reply #5 on: February 09, 2015, 10:53:54 PM »
Caught 24 today before weather shut me down.  I will take pics of my two Helix 5 and post them.
Offline PAPA BEAR
Re: Helix 5 DI GPS
« Reply #6 on: February 13, 2015, 02:39:52 PM »
Here the pics of where I installed my Helix 5 SI and DI
Offline PAPA BEAR
Re: Helix 5 DI GPS
« Reply #7 on: February 13, 2015, 02:40:45 PM »
DI up front
Re: Helix 5 DI GPS
« Reply #8 on: February 14, 2015, 09:43:41 AM »
Looks good Papa Bear ...
Offline mike23
  • Unit(s): Helix5 SI GPS
  • Software: Humminbird PC
  • Accessories: None
Re: Helix 5 DI GPS
« Reply #9 on: April 02, 2015, 10:47:51 PM »
Just got one other day
Any shallow water settings tips .. need all help I can get
Cheers
Offline PAPA BEAR
Re: Helix 5 DI GPS
« Reply #10 on: April 02, 2015, 11:37:55 PM »
Lots of good info here.  Best thing is to go out and adjust your settings. Spend time on the water seeing what different settings do. I have had to use different settings at the same location from one day to the next.  There are some good videos on SI settings on you tube.
Re: Helix 5 DI GPS
« Reply #11 on: April 03, 2015, 11:08:01 AM »
Papa Bear is right.
Really there are no best settings for any condition/water depth as there are so many variables involved.  In shallow water, depending on what I am looking for, I would throw out the generalized SI Range set to 2X to 3X settings and go with a much wider setting.  I've used 100+ feet when in only 3 feet of water.  That was with a 998 unit though, so you may have to pull that in with smaller display of the HELIX 5 SI-GPS units.
« Last Edit: April 06, 2015, 09:36:17 AM by Humminbird_Greg »
Offline coy
  • Unit(s): HELIX 5 SI GPS, HELIX 5 DI
  • Software: Default
  • Accessories: Default
Re: Helix 5 DI GPS
« Reply #12 on: April 03, 2015, 06:11:44 PM »
Greg,
  Why such a wide range in shallow water?  Going down to Reelfoot lake next week to crappie fish, and have only used my Helix 5 SI a couple of times.  Would be curious to know about the shallow waster due to that lake being shallow for the most part.  Thanks
Offline mike23
  • Accessories: None
Re: Helix 5 DI GPS
« Reply #13 on: April 03, 2015, 07:24:39 PM »
thanks guys
yeah realise need to adjust in different conditions
In regards to SD micro I put mine in but wasn't saving waypoints , taking snapshots
any ideas ...
Dean
Re: Helix 5 DI GPS
« Reply #14 on: April 03, 2015, 11:49:14 PM »
Cheers
Under the Sonar tab ...:
*Beam frequency to 83kHz/200kHz to take advantage of the added detail of the 20° 200kHz cone and the wider 60° coverage of the 83kHz cone ...
*Switchfire Clear for water shallower than 10ft and adjust Sensitivity up to an acceptable amount of screen clutter ...
*Switchfire Max for water deeper than 10ft and adjust Sensitivity down to an acceptable amount of screen clutter ...
*Fish ID =On ... You will grow to like this over time ...
*Surface Clutter =as high a number as you can stand the upper clutter on the screen ... Lower numbers filter out good echoes too ...
*Noise Filter = Off ... Unless there are noticeable interference lines on the screen ...
*Max Depth to 10ft below actual water depth for best ping performance ...
SI Range to less than 50ft until your eyes are trained to pick up things farther away ...
Under the SI Enhance menu ...:
*SI Sensitivity = adjust up to brighten/down to darken ...
*SI Contrast = 10-12 ... Higher to make harder structure stand out more (also makes image grainy) ...
*SI Sharpness = Off ... Higher to make fish echoes pop out (also makes image grainy) ...
Chart speed ...:
*Higher when viewing 2d for faster screen refresh ...
*Match boat speed when viewing SI for best perspective ratio of structure actual shape ...
Re: Helix 5 DI GPS
« Reply #15 on: April 03, 2015, 11:53:31 PM »
any ideas ...
Dean
Waypoints are saved directly into the unit memory ...
Go into the waypoint management menu under the Nav tab to see your waypoint library ...
Waypoints must be manually exported to the SD Card under the Nav tab/waypoints menu ...
Offline mike23
  • Accessories: None
Re: Helix 5 DI GPS
« Reply #16 on: April 04, 2015, 12:47:37 AM »
Thanks Heaps Rickie
That is very helpful info
just what I was after , what about the snapshots ?
Regards
Dean
Re: Helix 5 DI GPS
« Reply #17 on: April 06, 2015, 09:38:56 AM »
Screen Snapshots are saved directly to the MicroSD card.
Re: Helix 5 DI GPS
« Reply #18 on: April 06, 2015, 09:41:35 AM »
Greg,
Wider range = more coverage area.  Again, this was with a unit that has a much larger display.  It will also depend on the size of the structures you are looking for and what they are made of.  For smaller structure and those that reflect less sonar I would use a much shorter setting.
Last post December 31, 2014, 03:52:33 PM
Last post January 02, 2015, 08:59:09 PM
by Bayou Basser
Last post February 10, 2015, 04:31:51 PM
Last post February 27, 2015, 08:46:51 AM
Last post August 29, 2016, 10:15:47 PM
