Author Topic: navionics hotmaps card  (Read 10927 times)
Offline tblshur
  • Unit(s): 798ci hd si
  • Software: 7.120
« on: February 02, 2015, 08:31:10 PM »
1st post so if im doing it wrong please correct me. i have a hb 798ci hd si and got a navionics hotmaps premium card , i cannot get bridges or roadbeds anyone have any ideas. thank you   :) :)
Re: navionics hotmaps card
« Reply #1 on: February 03, 2015, 01:28:08 AM »
Look under the Chart tab in the HB main menu system for "Chart Detail Level" ...
Make sure this is set to "All" ..
Also look at your lake here ... This webapp has the same detail that the latest Navionics cards have ...
http://navionics.com/en/webapp
If your map card is older ... It is a known issue that Navionics has omitted a lot underwater structure detail in their newer cards because of some kind of conflict with some of their mapping data suppliers ...
What version is your card ... ??
« Last Edit: February 03, 2015, 01:36:04 AM by rnvinc »
Offline tblshur
  • Software: 7.120
« Reply #2 on: February 03, 2015, 09:54:43 AM »
thank you for your quick responce. my chart level is set to all, not sure what version means, but the # on card is MSD/PREM-E6 . thks again for help. :)
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #3 on: February 03, 2015, 04:58:08 PM »
There is a "nature of seabed" option that gives you an option to see things like creeks. I don't believe" all" turns that option on. Take a look anyway. Not sure if that helps the chip you have but it might. Bob
« Reply #4 on: February 04, 2015, 01:47:36 AM »
I found this ...:
http://www.bbcboards.net/humminbird-sonar-gps/307247-navionics-charting-questions-need-help-charting-5.html#post3214145
What you may need to do is Restore the Defaults on the Unit and power off, when you power back on go to your Chart menu Tab and make sure that your Chart Detail Level is set to Custom and that your Spot Soundings are Visible. You will then go under your custom settings and if there is an option for your creek channels then you will need to make sure that it is on or either visible. If there isn’t a setting for this option then it may not be available on that card. At that point you may want to contact Navionics to actually see if Creek Channels would be covered.
Offline tblshur
  • Software: 7.120
« Reply #5 on: February 05, 2015, 12:57:00 AM »
bobcoy and rnvinc thanks very much for your help , after doing those things still no submerged bridges. it has item 9bridges in custom settings. it does not have creek channels listed but on my chart it shows a small red line i think is the creek channels 2 red lines for river channels. road beds and bridges i dont have, latter today i will call navionics. thanks again for your help. i will post back what they tell me :)
Offline tblshur
  • Software: 7.120
« Reply #6 on: February 20, 2015, 10:07:27 AM »
update my post . i emailed navionics, after trying different things and sending 2 screen snapshots she said it was a hb software problem and she was contacting hb to see if there would be a software update to solve the problem. she will let me know. i told her also i put it in my sons lowrance it had the same problem, she said the lowrance may have the same software problem. any ideas thanks.  ::) :)
Last post February 05, 2010, 03:53:46 PM
Last post March 09, 2010, 06:49:33 PM
by Llunker
Last post May 20, 2010, 10:09:14 AM
Last post March 19, 2011, 05:27:29 PM
by SkeeterMatt
Last post August 18, 2011, 08:39:04 PM
by Gonzz
Last post February 17, 2012, 05:48:05 AM
by stillbear
Last post July 11, 2017, 09:38:13 PM
Last post December 24, 2020, 04:08:24 PM
by Mad Angler
