Author Topic: Making a second autochart card  (Read 13360 times)
Offline kerryd15
  • Unit(s): 798C SI
« on: January 26, 2015, 08:19:20 PM »
So I made some maps of certain areas of a couple local lakes. I made the card and it shows up on my unit. I purchased a second autochart card. I renamed the Lkmaster file on the second card- the original. I copied the Lkmaster file in the AC folder used to make the first card, onto the second card. both cards look the same- as far as folders setup. I put the second card in the same hummingbird unit and nothing shows!! What am I doing wrong. Do I need to map everything to this new card for it to work? Thought we could share our data by copying the AC file from one chip to another.
Offline D S
  • Software: 7.5
Re: Making a second autochart card
« Reply #1 on: January 27, 2015, 10:37:52 AM »
all i did was put the second (new)card in pc with auto charts and updated as per usual,same way i made the first one
it made a copy same as original,i didnt make any changes to file names etc on second card
dave
stgr
Offline kerryd15
  • Unit(s): 798C SI
« Reply #2 on: January 27, 2015, 04:17:04 PM »
From humminbird support. Each card has its own encryption, you can not copy the files from one card to another autochart card. you have to update each card through the program. I would assume I have to use the copy of the second card to create any mapping.
Offline kerryd15
  • Unit(s): 798C SI
« Reply #3 on: January 27, 2015, 04:21:19 PM »
Dave, If you don't change the name of the original LkMaster file on the card wont the program overwrite it? I just changed the name of the original LkMaster to the Do not delete.
Last post July 07, 2014, 01:17:43 PM
Last post June 02, 2015, 06:17:46 PM
by Bill H
Last post July 22, 2015, 01:44:15 PM
Last post February 12, 2016, 11:16:13 PM
by afaust
Last post March 27, 2016, 10:53:15 AM
by victor_humminbird
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post May 04, 2016, 09:48:33 AM
by N9Phil
Last post June 22, 2016, 09:42:55 AM
by TheGooly
