Author Topic: Trying to export waypoints from my 998c si  (Read 25002 times)
Offline grae46
  • Unit(s): 998c HD SI, 788ci HD DI
« on: January 25, 2015, 01:01:34 PM »
I'm trying to export the waypoints off my 998. I go to through all the steps and it will say "nav data successfully exported to mmc/sd card". Then I go put the sd card in my computer and there is nothing on it. Any ideas of what i may be doing wrong??
Re: Trying to export waypoints from my 998c si
« Reply #1 on: January 25, 2015, 03:15:05 PM »
Try using another card......Best to use a class 10 SD card....Humminbird recommends scandisk extreme.
Are you looking at the card with file explorer or Humminbird PC?
Offline grae46
« Reply #2 on: January 25, 2015, 03:22:11 PM »
I just tried viewing what is on the sd card when I first insert it into my computer. It should show something at that point right?
« Reply #3 on: January 25, 2015, 03:30:28 PM »
Yes....There should be files and folders on there.  What you see may depend on how you have the view set up on windows.
Offline grae46
« Reply #4 on: January 25, 2015, 03:36:16 PM »
Yeah it shows a few folders but nothing in them. I guess I'll have to try and get a scandisk extreme card.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #5 on: January 25, 2015, 03:45:07 PM »
Are you using HumminbirdPC?
« Reply #6 on: January 26, 2015, 12:54:12 AM »
Is the slide locked on the left edge of the SD Card ...??
« Reply #7 on: January 27, 2015, 02:03:16 PM »
What folders is it showing?
Have you tried formatting the SD card?
Offline grae46
« Reply #8 on: January 27, 2015, 02:18:24 PM »
The card is in the unlocked position.  I have not downloaded humminbird pc yet.  I was trying to get the waypoints on the gps first but I will download it now to see if that makes a difference.
I will attach a picture with what folders are being shown.  I'm not sure what to do to format the SD card.
« Reply #9 on: January 27, 2015, 03:15:30 PM »
There looks to be some additional folders on that SD card and these may be causing the problem.  When we get this straightened out you should see a “DATA.HWR” file under the “MATRIX” folder.
Since your PC is identifying the SD card as drive “E”, go to its rot directory and right-click it and select “Format”.  Be sure to uncheck “Quick Format”.
If that is an SDHC memory card and you have an old PC, then I would install Humminbird PC first and us the formatter in it so that the SDHC type memory card gets formatted correctly.
Offline grae46
« Reply #10 on: February 04, 2015, 08:11:12 PM »
Thanks Greg!  Reformatting the SD card and loading Humminbird PC to my computer seemed to have solved the issue.
Last post August 19, 2011, 02:04:34 AM
Last post June 10, 2013, 12:04:02 PM
Last post September 03, 2013, 12:10:23 PM
Last post October 04, 2014, 10:07:59 PM
Last post March 26, 2015, 08:24:16 AM
Last post November 26, 2015, 12:28:31 PM
by ezfishn
Last post December 12, 2017, 09:23:55 PM
Last post April 28, 2022, 10:52:00 PM
