Author Topic: 998 and i-pilot link connections  (Read 8254 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
« on: January 15, 2015, 08:23:44 PM »
I am going to put the i-pilot link system on my Terrova. Will I need a y cable of some sort to switch between the transducer on the trolling motor and the transducer on the stern for sideimaging, Di etc? I haven't received the system yet and just thought about this.
Thanks in advance.
Re: 998 and i-pilot link connections
« Reply #1 on: January 15, 2015, 08:39:48 PM »
I'm a little confused by your question.....are you talking about the I-pilot link communication, or the transducer connections.  That would be 2 different things.
What units do you have and where are they located?  We need more info about what you have and what you are trying to do.
Offline 6speedy3
« Reply #2 on: January 15, 2015, 09:05:49 PM »
I have a 998 on the dash and will be hooking the ethernet cable from the ipilot link to that. I think I am overthinking this. I believe the link communicates with the 998, via the gps in it and the us2 transducer in the Terrova, separate from the transducer mounted on the stern. No y cable needed?
« Reply #3 on: January 27, 2015, 02:37:58 PM »
No Y-cable needed.
The US2 is a separate system from the i-Pilot Link.
Offline 6speedy3
« Reply #4 on: January 27, 2015, 02:59:07 PM »
Thanks for the replies! As usual I was over thinking this. The 998 on the dash will be connected directly to the ipilot link via the ethernet cable and the 788ci, will be connected to the US2 as it was before, no link as the 788 is not ethernet compatible. Not going to buy a compatible unit at this time.
Last post July 18, 2012, 08:09:44 AM
Last post April 18, 2013, 03:56:39 PM
by Rotus623
Last post April 16, 2013, 12:42:46 PM
by scgmc
Last post April 23, 2013, 09:56:43 AM
by freezerfiller
Last post July 24, 2013, 09:26:19 PM
by ScottA
Last post June 30, 2014, 01:49:55 PM
Last post August 01, 2014, 12:27:31 PM
by Leif Snyder
Last post October 20, 2014, 08:52:51 AM
