Author Topic: Can a second SI be added to an already installed system?  (Read 8320 times)
Offline fishbone
« on: January 04, 2015, 03:20:39 PM »
I'm running a 998 SI with the transducer mounted on the stern with a second down image puck mounted in the bilge for depth readings on plane. The display is console mounted.
Question;
Can a second display be mounted at the bow that would use the present sensors. esentially tapping into the signal?
I'm looking to save some cost and not install a complete second system.
2013 Stratos 189 VLO
E-Tec 150 HO 150hp, 6" JP
80# Fortrex, 2ea 8' Power Poles
HB 998cSI @ Console, HB 999HD SI @ Bow
Re: Can a second SI be added to an already installed system?
« Reply #1 on: January 04, 2015, 06:03:08 PM »
If you are only going to use 1 unit at a time ... There is the HB US3 switch which would allow each head unit to be able to use the rear xducer/xducers separately ...(GPS, Nav data, Temp would come from their own respective head unit) ...
http://www.humminbird.com/Products/US3/
Ethernet can be run from your 998c to a bow mounted "Ethernet capable" HB unit ...
Depending on which unit you desire for the bow mounted unit will determine which of the following they will share thru the Ethernet ...Sonar, GPS, Nav Data, Temp ... (No map sharing) ...
If your desired bow unit choice is also a HB SI unit ... They can share 2d, DI, SI, GPS, Nav data, Temp thru the Ethernet ... (No map sharing) ...
NOTE ...: Onix and Ion will not Ethernet to any HB unit except Onix to Onix and Ion to Ion ...
If you can tell us which unit you are interested in ... We can tell you which of the features could be shared thru Ethernet ...
« Last Edit: January 04, 2015, 06:12:07 PM by rnvinc »
Last post April 01, 2009, 12:44:26 PM
Last post February 12, 2010, 01:00:21 PM
by keizerh
Last post February 28, 2011, 03:14:02 PM
Last post April 03, 2014, 11:12:28 AM
Last post February 26, 2015, 12:45:14 PM
Last post August 02, 2016, 12:15:33 PM
by D S
Last post January 23, 2018, 07:47:34 PM
Last post April 01, 2025, 07:31:42 AM
by 234rick
