Author Topic: no background map when zoomed in < 1000ft  (Read 21888 times)
Offline Koen Vandecauter
    • Hondengedrag
  • Unit(s): 798cxi SI HD
« on: December 04, 2014, 07:51:12 AM »
In Chart menu:
Chart select: AUTO
Base Layer: AC
Overlay: AC or OFF (doesn't matter)
zoom level 250m or 1000ft
same settings but zoomed in more and I lose my background map
playing with my map settings:
Chart select: AUTO
Base Layer: DEFAULT
Overlay: AC
background map and depth map not in line.....
any solutions to my problems?
Offline D S
  • Software: 7.5
Re: no background map when zoomed in < 1000ft
« Reply #1 on: December 04, 2014, 12:09:27 PM »
The AC basemaps here in Saskatchewan  are not very accurate...(not sure what they used as a background)
you can draw your own map background in GE save as kml and import
then in Ac select your own shoreline content
DS
stgr
    • Hondengedrag
« Reply #2 on: December 04, 2014, 12:22:45 PM »
Thanks for you reply Dave but the shorelines are looking OK in Autochart on PC and also when my base layer is AC on my unit and zoom livel is above 1000ft but when I zoom in I lose the background, that' is strange....
who has autochart running on his 788 or 798? what are your settings for Chart select,Base Layer and Overlay?
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #3 on: April 23, 2015, 11:23:59 AM »
I have the same unit 798 and autochart normal Canada and I do have the same behavior.
-depending the zoom i loose the lake shore lines,
-depending the soom I loose my depth lines,
-when i move my gps display my depth lines outside of the lake and later one it goes back nicely
I have all same issues as you have and so far have not found any solution. even on DEMO I see same issues
Offline Bubba Canuck
  • Unit(s): 1199ci HD SI / 999ci HD SI / 597ci HD DI
Re: no background map when zoomed in < 1000ft - HUMMINBIRD PLEASE HELP?!
« Reply #4 on: June 01, 2015, 12:16:58 PM »
Similar issue here.
When I zoom in to a certain level (e.g. the zoom level I need to see my contour lines properly) I lose the shoreline and blue water on the lake from the Zerolines card. So to some degree, this makes AutoChart almost useless for remote lakes.
HUMMINBIRD - IS THERE ANYONE THERE WHO CAN ANSWER THIS QUESTION PLEASE?
14' Lund "Tin Can", 25 hp Merc: $3,000
Humminbird 1199 CI HD SI Combo, Minnokota Terrova with iPilot Link and AutoChart Pro: $5,000
Humminbird 597 CI HD DI Combo: $600
Reaction from other Boats when Fishing: PRICELESS
Offline Beaulieu80
  • Software: 7.68
« Reply #5 on: August 26, 2015, 10:15:13 AM »
found a solution on your unit. make sure to have the latest Firmware on the unit.
go to Chart menu, at the bottom you have overlay, change to 100% and base overlay choose AC i think by memory,
this will allow you to keep the Zero line SD card as backgroud when you zoom in
« Reply #6 on: August 26, 2015, 10:39:36 AM »
Yes, thanks! I figured it out soon after I originally posted. Thanks for the reply though!
Last post July 18, 2009, 10:28:09 AM
by SIView
Last post March 23, 2010, 10:50:00 PM
by twobearlake
Last post April 04, 2010, 09:46:28 PM
by Blackwaterkatz
Last post May 23, 2011, 07:12:17 PM
Last post July 12, 2011, 03:00:16 PM
by nicknight
Last post September 12, 2015, 08:54:30 PM
by lancepeterson
Last post August 05, 2015, 08:55:35 PM
