Author Topic: linking to 1198  (Read 9224 times)
Offline beertech
linking to 1198
« on: December 02, 2014, 01:54:45 PM »
Re: linking to 1198
« Reply #1 on: December 02, 2014, 02:19:48 PM »
Yes......If you just have the 2 units and no other Ethernet accessories, you just need to connect the 2 via an Ethernet cable.
There may be some software dependencies ...... Greg or someone else will probably be able fill you in on that.  Some of the older revisions that your 1198 may not communicate properly to the newer software rev's.
You might have to rev up the 1198.
« Last Edit: December 02, 2014, 02:21:12 PM by Bob B »
Re: linking to 1198
« Reply #2 on: December 02, 2014, 02:49:15 PM »
Bob is right about the older software that you may or may not be running in your 1198 unit.
You will actually need two cables to connect them to each other.  One will be the AS-EC-QDE adapter cable to go from the 859 unit to one of the AS-EC-XXE Ethernet Connection cables.  The “XX” in the last cable name should get replaced by the cable length as they come in 2, 10, 15, 20 and 30-foot lengths (Ex: a 15 foot cable would be an AS-EC-15E).
Offline beertech
Re: linking to 1198
« Reply #3 on: December 02, 2014, 03:24:05 PM »
so what do i need to do about software.  I bought the unit new last may.
Re: linking to 1198
« Reply #4 on: December 02, 2014, 03:33:30 PM »
Check your 1198 unit to see what software version it has in it.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: linking to 1198
« Reply #5 on: December 03, 2014, 09:55:18 AM »
Beer, If you have not registered your units at Humminbird. com, do so. The latest releases and info there should help you out.
Offline beertech
Re: linking to 1198
« Reply #6 on: December 03, 2014, 11:08:37 PM »
okay will do.  also the new unit im buying comes preloaded with navionics will it show on both units if linked
Re: linking to 1198
« Reply #7 on: December 03, 2014, 11:20:58 PM »
There is no map sharing on the Humminbird core units ....only on the Onix.
Offline beertech
Re: linking to 1198
« Reply #8 on: December 10, 2014, 09:17:05 PM »
still havent pulled the trigger on buying this.  wondering if I would miss di on the front of the boat.  I have it on my console and barely use it but just got me thinking
Last post April 30, 2010, 11:25:10 AM
Last post August 30, 2012, 03:55:56 PM
Last post December 03, 2012, 12:38:53 PM
Last post April 15, 2013, 04:13:59 PM
Last post June 18, 2013, 01:20:39 PM
Last post August 18, 2014, 01:19:01 PM
Last post September 21, 2014, 09:25:37 PM
Last post March 04, 2015, 09:10:07 PM
