Author Topic: 999 Problem  (Read 7542 times)
Offline tomjohn
  • Unit(s): 899 & 788
999 Problem
« on: November 11, 2014, 09:27:29 PM »
Seems I lost my DI and SI on my Humminbird 999. The screens come up but they are enpty. NEED HELP
Re: 999 Problem
« Reply #1 on: November 11, 2014, 10:17:58 PM »
Check the "Transducer Select" menu under the Sonar tab to make sure "Hi Def SideScan" is selected ...(altho I would think even the SI and DI views would not show using a different selection)..
Also make sure the SI Range setting is set to a value that is more than the actual water depth ...
« Last Edit: November 12, 2014, 10:09:09 PM by rnvinc »
Re: 999 Problem
« Reply #2 on: November 12, 2014, 04:17:27 PM »
If that doesn't help; try cross-testing it with someone else's Humminbird Si model unit (any model will work for the test).
Offline Redge
  • Unit(s): 958, 1198
  • Software: 6.68, 6.74
  • Accessories: HS puck
Re: 999 Problem
« Reply #3 on: November 14, 2014, 05:44:05 PM »
I had the same thing happen last weekend kind of.  I hate to admit this, but after a while I realized I had somehow hit my switch to go to my thru hull ducer!!  Therefore you don't happen to have a switch to change between transducers do you?
Last post October 08, 2012, 02:08:10 PM
Last post May 18, 2013, 08:34:42 PM
by boydn1
Last post April 15, 2013, 05:46:54 PM
by LocoD
Last post July 29, 2013, 01:04:11 PM
Last post September 08, 2013, 08:07:14 PM
by LocDown
Last post June 15, 2014, 09:35:04 PM
by Alphahawk
Last post March 26, 2015, 11:16:11 AM
Last post November 12, 2015, 08:37:21 PM
