Author Topic: Man Overboard (MOB) can it be deActivated  (Read 7490 times)
Offline liketrolling
  • Unit(s): 598 and 998 si
« on: October 03, 2014, 12:04:04 PM »
I have a 998 upgraded to software 7.090
have a minnkota i-Pilot Link.
When I try to Create a Route using the Cursor and GOTO Key it sets of the MOB. and turns of the minn Kota.
MOB is activated even if I hold the goto key less then 1.5 seconds
this did not happen with the old up date.
Is there any way to get it of the 998 or deactivate it.
Offline sfw1960
  • Bringer Of The 'Bird
Re: Man Overboard (MOB) can it be deActivated
« Reply #1 on: October 03, 2014, 12:31:23 PM »
Have you tried "cancel navigation" ?
« Reply #2 on: October 03, 2014, 04:18:42 PM »
I can cancel navigation
and I can deleat the MOB
Can't Create a Route using the Cursor and GOTO Key you touch the goto button and the MOB red man comes up.
follow the contour works good when using the goto key
Offline sfw1960
« Reply #3 on: October 03, 2014, 05:06:29 PM »
Quote
[Navigation X-Press menu] [Cancel MOB] [right cursor] It also sets a red waypoint that you can delete as well.
   :o
« Reply #4 on: October 06, 2014, 12:21:54 PM »
There is no way to deactivate the MOB function.
Offline sfw1960
« Reply #5 on: October 06, 2014, 12:27:14 PM »
It can be cancelled (not deactivated)- correct?
« Reply #6 on: October 06, 2014, 12:31:08 PM »
Correct.
Disconnecting the GPS would also deactivate it as it is a GPS related function...
Last post June 24, 2009, 08:04:22 AM
Last post December 27, 2021, 03:42:01 AM
by Nexsim
