Author Topic: Connecting to Cobra VHF  (Read 6728 times)
Offline JWSimon
  • Unit(s): 798ci SI
  • Software: Original
« on: September 03, 2014, 10:16:16 AM »
Can someone help me with what I need to connect my GPS to a Cobra F55. I currently have an 1197c SI with external puck and a 798ci SI with internal GPS on the console and a 788 with internal GPS on the bow of my Skeeter MX1825. Which one of these units would be easiest to connect from and what hardware would I need. Thanks!
Re: Connecting to Cobra VHF
« Reply #1 on: September 09, 2014, 10:21:17 AM »
Welcome to the Humminbird Side Imaging Forums JW Simon.
Easiest would be the 1197c SI unit with its external GPS Receiver.
You need to set the NMEA Output menu in the 1197 unit to “On”.
You connect the NMEA output from the GPS “pigtail” wires to whatever adapter cable is needed for the Cobra F55 radio.  Depending on what version GPS Receiver you have and what NMEA sentence prefix the Cobra F55 needs will depend on how you connect the two.  The NMEA pigtail wire is the second, shorter, set of wires that come out of the connector for the GPS Receiver.  The end of the wire is covered with a black plastic cap.  Remove the cap and inspect the wires.  They will be either Red, White and Black or Green, White and Black.  The Black is the NMEA Ground (-) and either the White or Green is the NMEA Output (+) connection you need (try first one than the other).
Last post February 13, 2010, 07:21:59 PM
by Stymie
Last post April 14, 2010, 09:24:45 PM
by Gillfisher
Last post March 07, 2011, 06:41:14 PM
Last post May 18, 2011, 06:11:41 PM
by akgoff4
Last post May 24, 2011, 04:37:06 PM
Last post September 03, 2012, 10:44:57 AM
by Jdeee
Last post May 16, 2014, 11:31:05 AM
by Ryans Pappa
Last post June 29, 2014, 06:36:37 PM
by jjmoney
