Author Topic: ac folder  (Read 9423 times)
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
  • Accessories: autochart pro, ipilot
ac folder
« on: July 17, 2014, 09:08:35 AM »
Is it possible to delete the ac folder on the zerolines card and start again on your mapping of a lake??
Re: ac folder
« Reply #1 on: July 17, 2014, 10:13:33 AM »
I have not done so myself Mike but I believe that this is the only way to start mapping a lake again.  Hope that you made a copy of the Zero Line Map Card on your computer before beginning...
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
Re: ac folder
« Reply #2 on: July 17, 2014, 10:18:20 AM »
GREG
Thanks for the info.  i do have a copy made but will make another just to be safe
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
Re: ac folder
« Reply #3 on: July 19, 2014, 02:20:43 PM »
from what i understand with my autochart.
your custom maps are saved only into the AC folder and not inside the original zero line folder
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
Re: ac folder
« Reply #4 on: July 19, 2014, 03:40:38 PM »
thanks...have not tried it yet...still sorting out which recording i want to use before i begin afresh.
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
Re: ac folder
« Reply #5 on: August 15, 2014, 01:22:40 PM »
You can remove the \AC and the \SI folders if you want.   Just don't remove the LkMaster folder from the root of the SD drive.
I have data for so many lakes that I have recorded over the years that I need multiple AC folders.   Otherwise, processing is really slow.   When I am done with Lake Fork I rename that AC file to AC-Fork.    If I want to use my Sam Rayburn AC I rename my AC-SamRayburn to AC.  Same thing with the SI folders.
Offline Beaulieu80
  • Software: 7.68
Re: ac folder
« Reply #6 on: August 15, 2014, 04:04:16 PM »
ok but if you rename it do you still see other lake from the master zero line folder? when you travel to new lake?
Offline jimham82
  • Jim Hammond
Re: ac folder
« Reply #7 on: August 15, 2014, 11:09:50 PM »
You will only see the lakes that were built in the file currently named AC.
Last post April 15, 2013, 02:27:01 PM
Last post July 24, 2019, 04:41:12 PM
by gimez
