Author Topic: ONIX 10 & LakeMaster  (Read 13992 times)
Offline Thermite
  • Unit(s): Onix 10
« on: July 10, 2014, 02:24:40 PM »
I have the LakeMaster version 5 Great Plains card. I'm not sure that the unit is reading it at all. Nothing on the Map Source page says anything about LakeMaster. The page shows the same whether the card is in or not. Chart Card info says
 Embedded chart :NO.
 Network Chart : NO .
Card Status: Valid Card.
Only thing that changes is when the card is out, it says. No Card .
I bought it off of Amazon
Seems to me it should show what card it is ?
  • Moderator
Re: ONIX 10 & LakeMaster
« Reply #1 on: July 10, 2014, 03:17:36 PM »
I don’t think it will.
Did you try and look at a lake that on that map card and see if anything changed when it was installed?
Offline Thermite
  • Unit(s): Onix 10
« Reply #2 on: July 11, 2014, 09:30:10 PM »
I'll be back on the water in a few days and try it then
  • Moderator
« Reply #3 on: July 14, 2014, 08:33:38 AM »
If your boat is where the GPS Receiver can see the GPS satellites, then you can check it while on the trailer.  Just zoom out and move the cursor over to a lake that is covered by the map and you will see/not see the changes made by the LakeMaster map.
Offline Thermite
  • Unit(s): Onix 10
« Reply #4 on: July 14, 2014, 08:37:15 AM »
I did what you recommended and pulled the card , the card is good and works well. I guess I expected more?  Maybe the lake I was on lacks contour.
Thanks for the help
  • Moderator
« Reply #5 on: July 14, 2014, 10:25:10 AM »
That could be Thermite.  Which lake did you look at?
Here is a list of all the lakes on the Great Plains ver. 5 map card:
http://www.humminbird.com/uploadedFiles/Site_Assets/manuals/Product_Manuals_from_Shopatron/HB_GreatPlains_v5_2014.pdf
« Last Edit: July 15, 2014, 09:39:11 AM by Humminbird_Greg »
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #6 on: July 14, 2014, 07:31:26 PM »
That link is local to your HDD Greg!!   >:D
I don't want to pick your pockets..... ;)
TRY:
Offline Thermite
  • Unit(s): Onix 10
« Reply #7 on: July 14, 2014, 11:02:09 PM »
The lake was Branched Oak in Nebraska, guess there isnt much for contour changes there? Thanks for your help.
Offline CarolC
  • Unit(s): Onyx 8ci si , Onyx 10ci si
  • Software: 1.1
  • Accessories: lakeshore maps, ipilot link, e adaptor
« Reply #8 on: July 15, 2014, 08:42:50 AM »
sounds like autochart will be free for onix users soon, you can then do your own overlays!  My dad used to fish Branched Oak a lot! I was there decades ago!.
  • Moderator
« Reply #9 on: July 15, 2014, 09:48:57 AM »
TRY:
Thanks Robert, I went back and changed the link in my post.  Guess I must have saved that document before I posted it.
Thermite, Branched Oak should be a High-Definition Survey, so if it is not showing much in the way of contour changes there just may not be any.
Yes CarolC, you will be able to make your own maps using only your ONIX unit when the download comes out.  You won;t have as many options as you would with the full AutoChart software but you will have everything you need to map or update a map within the unit.
Offline sfw1960
« Reply #10 on: July 15, 2014, 10:06:07 AM »
ANYTIME I can help, say the word Greg!
I might have to move down there & get a different gig!   ;D
by Nitro78
Last post June 28, 2014, 02:25:09 PM
by CarolC
Last post January 31, 2014, 05:45:03 PM
by LittleGazoo
Last post April 02, 2015, 08:41:23 AM
by nwifishnut
Last post April 23, 2015, 11:10:06 AM
Last post February 29, 2016, 09:54:06 PM
Last post April 08, 2016, 10:54:08 AM
by RonnieB
