Author Topic: HB's RF Reduction kit  (Read 15455 times)
Offline George
  • Software: Always up todate
« on: April 10, 2009, 11:06:21 AM »
Does any on know what is included in HB's RF noise reduction kit?
Re: HB's RF Reduction kit
« Reply #1 on: April 10, 2009, 01:32:45 PM »
That depends on which kit you get which also depends on what Humminbird equipment you tell tham you have.
Currently all kits have: Trolling Motor Choke, and Power Cbale with Choke.  They may also include a Copper (was Nickel but we switched for easier manufacturing) coated HDSi transducer and/or Ferrite Rings (for the InterLink module).
Offline George
« Reply #2 on: April 10, 2009, 03:50:38 PM »
Thanks Greg,
The reason I asked was that they sent me a new TM Transducer (which I did not expect), but there was not a choke or any other RFI reduction devices.
« Reply #3 on: April 13, 2009, 05:39:27 PM »
George,
Try the transducer out and if it doesn't do the job call them back for the other parts.
Offline SpineyNole
  • Unit(s): 1197c si
  • Software: 4.950
  • Accessories: custom towfish
« Reply #4 on: September 22, 2010, 02:49:15 PM »
Greg,
What is the part number for a RF noise reduction kit for the 1197c si unit? I am looking to purchase the new HDSi transducer that has the built-in copper shielding for my towfish.
Thanks,
Keith
« Reply #5 on: September 22, 2010, 04:29:36 PM »
Keith,
You don’t have to buy the RF noise reduction kit just to get the copper coated HDSi transducer as we have been building everyone of them that way since about August of 2008.
Offline SpineyNole
  • Unit(s): 1197c si
  • Software: 4.950
« Reply #6 on: September 23, 2010, 11:52:15 AM »
Thanks Greg... What does the RF noise reduction kit offer over just the transducer? I already have chokes installed in the power cables.
BTW, is the 455/262 KHz transducer built with the same kind of shielding?
I am currently using the 455/262 KHz  transducer in my towfish and am experiencing RF noice when I start my genset. I have isolated the 1197c from onboard power by using a stand-alone battery, but that did not help. I am using high grade Belden cable as suggested by HB but noise is still getting in.
Any suggestions?
Keith
« Reply #7 on: September 23, 2010, 02:27:05 PM »
It would depend on which interference kit you get Keith.  Some have either:
 - the Trolling Motor Choke, the PC-11 Power Cable and Ferrrite Rings (no transducer)
 - the Trolling Motor Choke, the PC-11 Power Cable, Ferrrite Rings and the XHS-9-HDSi-180-T transducer
- the Trolling Motor Choke, the PC-11 Power Cable and the XHS-9-HDSi-180-T transducer (no Ferrite Rings)
Yes the XHS-9-Si-180-T (262/455kHz) transducer is built with the same copper coated housings as the HDSi transducers are.
I would try building a grounded shield around the genset if at all possible.  This could be something like a piece of bent tin with a grounding wire.  Keep the unit, towfish and all cables as far away from the genset as possible.
Offline jsplinter
  • Unit(s): 997, 798
« Reply #8 on: January 14, 2011, 07:31:38 PM »
Greg,
where do you purchase these RF lits? I looked online and cant find anything. also i will put this on here as well I am moving my 798 to the console, am i correct in i need to use 18GA wire, or is their a different size you reccomend? thanks
Josh
« Reply #9 on: January 15, 2011, 09:40:50 AM »
Josh,
The trolling motor noise reduction kits are only available through Humminbird (and maybe Minn Kota).  Just call the Humminbird Customer Resource folks at 1-800-633-1468 and ask about them.
As for extending the power wires for the 798 unit.  The PC-11 that goes to that unit is 18 gauge wire.  I always go up a gauge size if I have to run extension wires, due to the drop in voltage over distance.  So I would look for a 16 gauge multi stranded wire (my Nephew-in-law uses outdoor grade extension cords for this).
Offline jsplinter
  • Unit(s): 997, 798
« Reply #10 on: January 16, 2011, 06:41:38 PM »
thanks greg, i will look into both of those
Last post August 05, 2009, 03:04:43 PM
by ITGEEK
Last post October 13, 2009, 09:29:33 AM
Last post July 09, 2014, 04:31:15 PM
by hunter
Last post May 19, 2014, 10:58:39 PM
