Author Topic: Mapping with 200 Khz and Dr.Depth  (Read 10711 times)
Offline DiveExplorer
« on: June 18, 2014, 11:02:40 AM »
Have you ever mapped a lake or something else using only 200 Khz.
My sonar seems not have 83 khz but 200/455/ and 800 Khz. I was wondering if that would be a problem as 200 khz cone is smaller than 83 khz.
Re: Mapping with 200 Khz and Dr.Depth
« Reply #1 on: June 18, 2014, 12:03:43 PM »
Which Humminbird model unit do you have DiveExplorer?
It sounds like you have one of the DI models with those frequency selections.
« Reply #2 on: June 18, 2014, 01:14:59 PM »
Yes, I have 581i HD.
Offline Rüdiger
« Reply #3 on: June 20, 2014, 08:27:37 AM »
Hi DiveExplorer
You can also work with the other frequencies, but among them may suffer accuracy because DrDepth emanating from a recording at 200kHz.
I myself have created a map with the 800kHz sidecan information.
mvh
Rüdiger
Finding is better than losing
« Reply #4 on: June 20, 2014, 01:19:58 PM »
Thank you for the reply Rüdiger.
I was just concerned that I bought a wrong sonar to use for mapping. I thought 581i HD had 83 Khz also.
If  i can use 200 Khz for both mapping depth and hardness than it would be enough. I was thinking that using only 200 khz it would cover a lot less area than 83 khz.
Last post January 22, 2013, 04:21:30 AM
by Rüdiger
Last post June 04, 2013, 09:37:21 PM
by matt 01
Last post June 18, 2013, 12:44:31 PM
Last post June 18, 2013, 02:15:13 PM
Last post August 05, 2013, 05:18:35 PM
by Austin358
Last post December 06, 2013, 11:50:56 PM
Last post June 25, 2016, 06:33:10 PM
by Spd 135
Last post July 26, 2017, 12:52:40 PM
by Mark Saikaley
