Author Topic: AutoChart file conversion problems  (Read 22598 times)
Offline fresque93
  • Unit(s): 997SI, 858c
  • Accessories: Interlink
« on: June 01, 2014, 12:45:56 PM »
Is anybody else having problems exporting their maps back to the unit for a non updated unit? I've used the conversion instruction sheet, but i feel like im missing something, or im moving the wrong files etc. Love some help if anybody knows!
Offline CamoHunter
  • Unit(s): 1199ci HD SI, 788ci HD, 788ci HD
  • Accessories: AutoChart Pro, Terrova 80 - iPilot Link
Re: AutoChart file conversion problems
« Reply #1 on: June 19, 2014, 11:48:10 AM »
Hey, what are you having trouble with?
I have messed with mine now finally. As stressed by Humminbird, I did not delete or alter the original "AC" folder or "LkMaster" folder.
So...
I renamed the "LkMaster" folder to "0LkMaster-DO NOT DELETE".
I renamed the "AC" folder to "0AC-DO NOT DELETE".
That way when I look at the contents of the Zerolines SD card on my computer, I know that those two folder are the originals and should not be messed with.
When I first got my copy of Autochart, I set up the program to read and write to a local copy of the SD card (so I don't have to have the Zerolines SD card in my computer to save/update my lakemaster maps).
So when I created a new lakemaster map, it is save in C:/Autochart/LkMaster/AC
Once you have your map how you want it, copy the "LkMaster" located inside the AC folder from your hard drive, to the root of the ZeroLines SD card.
I didn't have any issues, and it worked just as a normal lakemaster card.
Offline CamoHunter
« Reply #2 on: June 19, 2014, 07:22:24 PM »
I created a little tutorial file to show the process.
It shows the steps needed to use your ZeroLines SD card and your custom map on a Humminbird unit that does not have the software update on it yet.  This is how I got it to work on my 788ci HD.
Download the .pdf file below, and let me know if you have any questions.
« Last Edit: June 19, 2014, 07:23:44 PM by CamoHunter »
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #3 on: July 14, 2014, 12:50:54 PM »
I have updated my unit firmware and I was able to see my custom maps but had to rename and copy my maps to the SD card root.
Offline D S
  • Software: 7.5
« Reply #4 on: August 06, 2014, 10:13:20 PM »
just got a card to try on 798 copied lkmaster folder to desktop ,
but I don't have a AC file on my new zerolines card? to copy
what am I missing ???
looked at  hummingbird tutorial doesn't say anything about copying AC file
tried to create map  but it gives me an error says to check getting started for help??
 how do I fix it I want to use the local copy option si I can use on my 798
ds
stgr
Offline D S
  • Software: 7.5
« Reply #5 on: August 06, 2014, 10:36:51 PM »
do you have to first initialize a map on card then copy all files to pc so there is a AC file to copy to the pc hardrive??
what am I missing ? as I said this is a brand new zerlines card ....and all it shows is a  LKmaster file
ds
stgr
Offline D S
  • Software: 7.5
« Reply #6 on: August 06, 2014, 10:56:21 PM »
error message idf I try to write to card
stgr
Offline D S
  • Software: 7.5
« Reply #7 on: August 07, 2014, 11:10:44 AM »
has an yone else tried  to make a second   map card  on  thier autocharts program?
my first one was to the zerolines card as 1198 has an update ..
second to local copy as my 798 does not  ...having troubles:(
best i can do after hours of trying ... is get my shorelines on chip but cant see map!
ds
stgr
Offline CamoHunter
« Reply #8 on: August 07, 2014, 11:56:29 AM »
Dave, I'll be able to help you with this later.  Probably this afternoon.  Heading out the door now though.
Offline D S
  • Software: 7.5
« Reply #9 on: August 07, 2014, 02:15:09 PM »
will this  work on 798csi non HD older unit? software 6.3?
I called HB support not much help
ds
stgr
Offline CamoHunter
« Reply #10 on: August 07, 2014, 07:59:46 PM »
Yes, you can get it to work on ALL Humminbird units that have an SD card and accept a mapping chip.  You just have to use a work around to do it, which isn't too difficult.
Offline D S
  • Software: 7.5
« Reply #11 on: August 08, 2014, 10:26:15 AM »
i finally got the file to sd card as per instructions it will display on my 1198 but not older 798 non HD unit??
has anyone got one running on the older non HD series units
stgr
Offline Beaulieu80
  • Software: 7.68
« Reply #12 on: August 14, 2014, 01:06:37 PM »
Have you try to do those steps from Humminbird guide?
see my attach PDF file
Offline D S
  • Software: 7.5
« Reply #13 on: August 14, 2014, 01:39:26 PM »
yup have been dealing with HB support for past 3 days......
ill update this  string once I get a solution
ds
stgr
Last post March 30, 2012, 10:12:31 AM
Last post May 07, 2013, 04:06:13 PM
Last post June 12, 2013, 12:09:27 PM
by LittleGazoo
Last post July 24, 2014, 02:17:24 PM
Last post February 17, 2015, 09:40:48 AM
by bobbyb
Last post September 02, 2015, 04:29:51 PM
by norj
Last post April 09, 2016, 09:42:21 AM
by nwkramer
Last post January 29, 2020, 04:22:18 AM
by Rüdiger
