Author Topic: Weathersense hook up  (Read 15040 times)
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« on: May 31, 2014, 09:07:19 AM »
Want to hook up a "Weathersense" to my 998. Besides SI transducer I also have a through the hull transducer.
Would the Weathersense use the "Y" cable and plug into the "Comm/GPS" port?
Offline Trytoofish
  • Software: 2.0, 7.51,
Re: Weathersense hook up
« Reply #1 on: May 31, 2014, 11:17:18 AM »
it gets plugged in to the acc side of the gps y cable.external gps gets plugged in to the com/nmea side
Try Too Fish  Forced To Work
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #2 on: May 31, 2014, 11:27:06 AM »
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #3 on: July 05, 2014, 09:57:33 AM »
So does the y-cable plug directly into the 998 unit, then the GPS & Weathersense plug into y-cable. What is the Pig tail on the GPS wire do, if anything?
« Reply #4 on: July 07, 2014, 10:17:50 AM »
That is correct fishnnnn.  Both the external GPS Receiver and WeatherSense get plugged into the AS-YC cable and the AS-YC cable gets plugged into the NMEA port connection on the unit (the transducers have their own set of y-cables).
That pigtail wire is for an NMEA 0183 output connection if it is needed.
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #5 on: July 07, 2014, 10:25:43 AM »
Thanks! Looks like I have to order an extention cable also. Way mine is mounted the 2 plug ends on end of y-cable would be exposed at all times.
The
I ordered the AS EC10 cable. I assume that plugs directly into back of unit then y-cable to that.
« Reply #6 on: July 07, 2014, 01:52:48 PM »
Yes it will.
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #7 on: July 08, 2014, 06:51:29 AM »
Thanks for your help.  I have unit hooked up and seems to work fine. Last question,  I hope,  does the Weathersense history track even if unit,  998, is off? Assuming the history feature is "On"
« Reply #8 on: July 08, 2014, 11:01:58 AM »
Yes it does as long as the internal Lithium coin cell battery is still good.
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #9 on: July 11, 2014, 10:49:16 PM »
So not my last question! Trying to figure out indications. Arrow on left between the +/- sign it never moves does it? What point/value does it represent? Last,  what is the value of each bar on the history track?
« Reply #10 on: July 14, 2014, 08:45:48 AM »
Yes the arrow does change.  It represents the trend for the barometric data based on past readings.
Last time I checked this each bar represented 0.5mb.
Last post June 06, 2009, 11:00:52 PM
by reddog
Last post May 24, 2012, 07:23:40 AM
Last post June 06, 2012, 07:20:25 PM
Last post August 13, 2012, 01:16:47 PM
by Roddy
Last post May 28, 2013, 10:39:52 AM
Last post January 17, 2014, 12:33:16 PM
by gnettlesjr
Last post July 04, 2019, 04:20:34 AM
by fishreed
Last post October 07, 2020, 12:38:11 AM
