Author Topic: New owner update question  (Read 15072 times)
Offline Mullethead
  • Unit(s): 1199si
« on: May 29, 2014, 06:39:33 AM »
Just purchased the 1199 SI and updated to 7.02 version. I have a problem where if I keep going through different views, the unit will shut down instead of cycling back to the first view. Do I need to also install previous updates or does the new version contain all the previous changes?
Mullethead
Re: New owner update question
« Reply #1 on: May 29, 2014, 08:34:36 AM »
Welcome to the Humminbird Side Imaging Forums Mullethead.
The current software update has all previous software versions in it.
Make sure that your power connections to the new 1199ci HD Si unit are all good.  No loose of corroded connections even on the fuse, fuse holder and battery connections.
Offline Mullethead
  • Unit(s): 1199si
« Reply #2 on: May 30, 2014, 02:53:12 PM »
Connections all good- brand new unit. I assume it should go back to first view when scrolling through? Have you run into this before?
Mullethead
« Reply #3 on: June 02, 2014, 10:13:58 AM »
Not with this software version though we have seen it in older versions of software, especially if you started pressing the VIEW button when it was just starting up.
Yes, when continuing to press the VIEW button it should start back over at the first View, once you have gone through all that are available.
Not sure what is causing this, anyone else running an 1199ci HD Si unit with the 7.020 version software in it?
Offline rpro
  • Unit(s): 999ci HD SI, 1199ci HD SI
  • Software: 7.02
  • Accessories: AS ETH 5PXG, AS ETH NMEA2K
« Reply #4 on: June 04, 2014, 08:54:47 PM »
I updated my 1199 to the 7.020 tonight and I can cycle through all screens repeatedly.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #5 on: June 08, 2014, 07:09:09 PM »
Did you reset to defaults AFTER the update was performed?
I read elsewhere this worked for some folks - then customize away....
Offline rpro
  • Software: 7.02
« Reply #6 on: June 08, 2014, 10:12:13 PM »
I don't recall. But FYI when I tried to update my 999 to 7.02 it locked up at the "Shutting down..." Screen.
Ended up that when I pulled the power after an hour and tried to restart it just kepit cycling shutting down screen then rebooting - an endless loop. HB sent me a shipping label so they could get it back to get it back up and running.
Offline sfw1960
« Reply #7 on: June 08, 2014, 10:31:41 PM »
Bummer.
I have never had a flash go bad, but I always make sure I have a good power connection - like the battery with the charger on it! AND that everything's been fired up & settled in for a few minutes (knock wood) before the card goes in the slot. I have to wonder if the downloads sometimes get corrupted & the ROM to be installed is just no good?
Anyways - hope HB gets you back up & running in short order - the transit time is usually what takes the longest, you should have it back by next Friday as long as you're stateside.
Last post June 15, 2011, 02:20:12 PM
by kwelklin
Last post September 04, 2012, 01:16:33 PM
Last post February 01, 2013, 01:38:19 PM
by ScottMN
Last post August 22, 2013, 10:18:35 AM
by Poorman
Last post October 23, 2013, 08:48:43 AM
Last post April 01, 2016, 07:29:19 PM
by RonnieB
Last post July 11, 2016, 04:03:55 PM
by snooktarpon
Last post February 16, 2018, 11:47:45 PM
by cramar_2112
