Author Topic: GPS antennae blown again !  (Read 8689 times)
Offline oz
  • Unit(s): 898si
« on: May 23, 2014, 04:33:36 PM »
I'm a professional charter skipper in the uk , I replaced the antennae a year ago under warranty and alas it has blown again, no GPS signal again
Is  this a common fault ? I don't think I can afford to operate a professional vessel with unreliable Gps
Are there any other products I can purchase to replace the humminbird antennae ?
Cheers oz
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: GPS antennae blown again !
« Reply #1 on: May 24, 2014, 03:55:27 PM »
Want a reliable GPS, go buy a Garmin for your mapping.
Humminbird GPS have problem on multiples units.
My 798 loose GPS signal at least 1-2 times each weekends and the tracklog have bogus positions points in them. I use a Garmin GPS to feed position data to my 798.
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
« Reply #2 on: May 26, 2014, 07:41:33 AM »
A hand GPS Garmin 60 is more accurate than HB GPS...
Offline oz
  • Unit(s): 898si
« Reply #3 on: May 26, 2014, 11:39:19 PM »
Please excuse my ignorance, do the gar in GPS receivers have the same plug connections as humminbird ?
Offline xSilmarilSx
« Reply #4 on: May 28, 2014, 03:59:59 AM »
Some (but not all) will output NMEA data to your HB unit via a special cable.
« Reply #5 on: May 28, 2014, 08:37:39 AM »
oz,
Our external GPS Receivers do not fail all that often, we have had more reported problems with the internal GPS Receivers from the posts that I have read.  If this is your second one to fail could you r installation location be causing this?  Where is it installed?
Many Humminbird units will accept GPS position data from an NMEA 0183 source but you will need the AS-HHGPS to make the connection to the Humminbird unit.
Last post November 06, 2012, 10:35:24 AM
by Bobcat316
Last post May 11, 2015, 09:23:31 AM
by allanrbaker
Last post January 30, 2016, 10:23:17 AM
by bobcoy
