Author Topic: Matrix 97 Software Update  (Read 54282 times)
Offline Maxposeidon
  • Unit(s): Matrix 97
  • Software: original
  • Accessories: GPS, Transudcer
« on: May 18, 2014, 12:58:58 PM »
Hi,
I have a Matrix 97 Combo with transducer and GPS AR-16, bought in 2007 SerialNr attached PIC and following problem. I had registerd the unit on the old webside, but with the new webside i am not registered anymore. Trying to re register don't work and the unit has following problem.
On the self test the unit says that the GPS is not connected. I brought it to a technichian and he said may be a software Update fix it. But as i cannot register i cannot get a Software Update. is there any option that you can send me the file email.
Thanks Max
Re: Matrix 97 Software Update
« Reply #1 on: May 19, 2014, 02:41:02 PM »
Welcome to the Humminbird Side Imaging Forums Max.
Call the Humminbird Customer resource folks to get the registration figured out.
If you just want the software for the Matrix 97 I can send it to you.  The last version released for the Matrix 97 was 4.750.  If your unit is already running this version it will not load again unless you first load an older version and then the 4.750 version again.
I don’t know that loading a new version of software will help though and would encourage you to do some trouble shooting before loading any software.  If you can find someone else that has a Humminbird unit that is also using an GR16 GPS Receiver, you can try cross-testing with them.  This does not have to be another Matrix 97 unit as we made many models that use the same power cable and GR-16 GPS Receiver.  You will know it is a GR16 GPS Receiver due to the dark gray gasket between the upper and lower housings and the printing on top will read: “GPS ACCESSORY SYSTEM” under “HUMMINBIRD”.
You should also take the black plastic cap off the second cable that comes out of the connector for the GPS Receiver.  This is the NMEA pigtail wire.  Once you remove the black plastic cap separate the three wires and test the unit again.  If it starts working it means that the wires were shorted.  Either way, cut/trim and seal the wires back so that they do not short out.
Offline Maxposeidon
« Reply #2 on: May 19, 2014, 03:17:56 PM »
Greg,
for sure the 4570 Version is not installed so please send it. No other Humminbirs around this area so i want to try with the updated software.The one installes is a 2.... or 3....., did also the cavle trick with the PIN and not worked so please send me the update
Cheers Max
« Reply #3 on: May 19, 2014, 03:25:09 PM »
On its way to you max to your listed e-mail address!
Coming via TransferBigFiles.com
Offline Maxposeidon
« Reply #4 on: May 19, 2014, 03:44:06 PM »
Got it, thanks will let you know what happenes.
Cheers Max
Offline Maxposeidon
« Reply #5 on: May 19, 2014, 07:01:03 PM »
Greg , how can i transfer this file to the GPS without the cable ?
Thks Max
« Reply #6 on: May 20, 2014, 10:55:39 AM »
By using an SD or SDHC memeory card - check your e-mail Max for more details.
Offline Maxposeidon
« Reply #7 on: May 22, 2014, 02:03:57 PM »
Greg,
just got the unit updates with the new software.
Still it always says GPS not connected on the selftest, either with the new GPS or the old one.
Another idea ?
THKS
Max
« Reply #8 on: May 22, 2014, 02:21:20 PM »
Max,
Is there any way that you can remove the black plastic cap off the NMEA pigtail and check for 12 volts in between the Red and Black wires?
You are testing this outside so the GPS Receiver can get the signals from the GPS satellites, right?
Offline Maxposeidon
« Reply #9 on: May 22, 2014, 02:49:47 PM »
Greg i could do yes outside on the selftest screen battery shows voltage of 13,5 V
Let you know
Max
Offline Maxposeidon
« Reply #10 on: May 22, 2014, 02:59:59 PM »
Greg,
the cables are black, white and green NO RED which one i should check old GPS
Max
Offline Maxposeidon
« Reply #11 on: May 22, 2014, 03:20:06 PM »
Greg here some PICS
« Reply #12 on: May 22, 2014, 03:28:49 PM »
Max,
Does your old GPS Receiver have the red wire?
It looks like on one of your pictures that you cut the main GPS cable.  Did you cut the main cable to the GPS Receiver?
Offline Maxposeidon
« Reply #13 on: May 22, 2014, 03:51:21 PM »
Greg ,
here you see PIC Unit on board with the new GPS and without the Cap on the NMEA pigtail and also the same don't work GPS Not connected and cables on the pigtail are black , green white like on the old one
Max
Offline Maxposeidon
« Reply #14 on: May 22, 2014, 03:58:12 PM »
Greg on the last pics i upload you can see some change happened to the unit, connected on the boat with the new antenna is shows temperature on the old one not
Max
Offline Maxposeidon
« Reply #15 on: May 22, 2014, 04:00:50 PM »
Greg, here again the old antena to the gPS with red, white , black and green cable and the other one shows the pigtail with 3 cables NO RED ONE
Max
« Reply #16 on: May 22, 2014, 04:02:17 PM »
Max,
If the wire colors on the older GPS Receiver are Black, Green and White than it was not the original GPS that we shipped with the Matrix 97 units and will make troubleshooting more difficult.  What I was trying to get you to do is confirm that there was voltage going to the GPS Receiver which can be done by checking for 12 volts between the Red and Black pigtail wires.  The newer GPS Receiver cables do not have the Red wire, so it cannot be checked there.  However, if you have already cut the main GPS Cable (the one that runs from the connector to the actual GPS Receiver) you can still check between the Red and Black wires of that cable for the 12 volts.  Otherwise there is nothing else you can check or test as you said there are no other Humminbirds in the area.
« Reply #17 on: May 22, 2014, 04:04:18 PM »
Max
Guess I was trying to post at the same time you were Max.
Connect up the old GPS Receiver and test between the Red and Black wires in the main cable (not the pigtail) for 12 volts.  I’m actually hoping that it is not there.
Offline Maxposeidon
« Reply #18 on: May 22, 2014, 04:14:38 PM »
Greg checking the red and black cable it shows 3- 4 V
Max
Offline Maxposeidon
« Reply #19 on: May 22, 2014, 04:25:15 PM »
It shows around 4 V Greg red and black in the main cable
MAx
« Reply #20 on: May 22, 2014, 04:28:20 PM »
Okay Max, that was sort of what I was hoping for although it does mean that the voltage circuitry for the accessories (your GPS Receiver) has been damaged,  A way around this is to power the GPS Receiver externally by wiring into a +12 volt and ground source on the boat.  The +12-volts goes to the Red wire and the Ground goes to the Black wire.  the Red wire between the connector and the point that you splice in the +12-volts needs to be cut so it does not feed into the unit, the Ground/Black wire should connect to both the unit and GPS Receiver.  I would install a power switch and fuse (1-Amp is large enough) in line with the 12 volt connection.  I hope that you understand the connections here.  If you did, this should provide power to the GPS Receiver which will start sending the data to the Matrix 97 unit.  Not pretty but it’s a possible way to get your GPS up and running.  Otherwise you would have to send your Matrix 97 in to be serviced (if we still can) and it won’t be cheap to do so (you may be better off buying a new unit at that point).
Offline Maxposeidon
« Reply #21 on: May 22, 2014, 04:38:19 PM »
Thanks a lot will talk to the TEC and let you know
Max
Offline Maxposeidon
« Reply #22 on: May 27, 2014, 03:37:57 PM »
Hello Greg,
latest update, Unit works again, it was not elcetricty problem with the cables. Our Tech changed the PINS
in the unit where you connect the GPS cable and perfect.
I think it was corrosion due to saltwater.
See ya
Max
Offline flamesay
  • Unit(s): matrix 97
  • Accessories: Combo
« Reply #23 on: July 09, 2016, 02:55:45 PM »
Hello,
I have trouble registering my matrix 97 on the web, shows me that my serial numbre is not correct.
Can you send me 4,750 firmware please?
flamesay (@)  hotmail.com
regards
« Reply #24 on: January 17, 2017, 12:11:42 PM »
Hello,
regards
Sorry for the late reply ...
sideimagingsoft is not owned by HB ... we are simply a group of HB users sharing knowledge to try and learn the products better ...
Contact HB for help with getting a software version for your Matrix ...
http://www.johnsonoutdoors.com/Main.aspx?id=127
Last post September 22, 2009, 12:51:11 PM
Last post March 10, 2012, 09:49:36 PM
by Moose1am
Last post July 03, 2012, 02:02:12 PM
Last post January 17, 2014, 12:33:16 PM
by gnettlesjr
Last post March 31, 2014, 12:36:06 PM
Last post May 11, 2016, 11:17:36 PM
Last post July 09, 2016, 08:53:48 PM
Last post October 05, 2017, 04:46:56 PM
by Reel of Fortune
