Author Topic: Hdsi trancduser with lowrance elite 5  (Read 7257 times)
Offline pimpelkungen
  • Unit(s): 899ci hd si
« on: April 28, 2014, 03:04:35 AM »
Is there some way you can interface The hdsi ducer with an elite 5, only the 200khz signal?
Re: Hdsi trancduser with lowrance elite 5
« Reply #1 on: April 28, 2014, 12:40:46 PM »
I’m sure it could be done but you would have to cut the connector end off of the HDSi transducer and solder on a Lowrance connector.  You would need the pin out for each transducer.
« Reply #2 on: April 28, 2014, 02:05:22 PM »
My plan is to use the 899 only as a SI and the lowrance unit as a 2d on the same tranceduser, maybe i can split the signal with one of the Y-cables ?
« Reply #3 on: April 28, 2014, 03:23:06 PM »
None of our transducer splitter cables work that way (splitting the signals from one transducer to two units, they actually combine the sonar signals from two transducers to one unit).  Doing this would cause all of the automatically setting within the 899 unit that rely on the 2D water depth to not work and slow down the Si sonar.
Last post February 29, 2012, 06:16:11 PM
by SFS
Last post April 28, 2013, 06:51:11 PM
by cfleague
Last post June 13, 2013, 11:05:36 AM
Last post July 11, 2014, 11:22:54 AM
by nwifishnut
Last post March 11, 2016, 03:08:50 AM
by Superterrorizer
Last post December 23, 2017, 05:12:58 PM
by steelebob
Last post February 16, 2018, 11:47:45 PM
by cramar_2112
Last post April 05, 2018, 03:53:16 PM
by iceperch
